AMC 304 Mechanical Fuel Pump - JeepForum.com
 1Likes
  • 1 Post By 82JeepCJ7
post #1 of 9 Old 01-28-2019, 10:27 PM Thread Starter
MarkVMod0
MarkVMod0's Avatar
1976 CJ5
I have decided to go back to the mechanical fuel pump but I see the pump arms are different depending on the year the engine was manufactured.
The 304 on this 76 CJ has a valve cover tag that reflects the engine was manufactured in 1972. My dilemma is how can one tell what fuel pump to use? Engine may be a 76 with 72 valve covers but only the PO knows and I have no idea where he is.
You guys have any tips for figuring out what fuel pump to use?
Mike
MarkVMod0 is offline
post #2 of 9 Old 01-29-2019, 12:21 AM
only in a jeep cj
I don’t believe it’s an arm difference rather than an inlet port direction difference. The CJ frames are different between pre 76 and post 76 so the fuel lines leading up to the pump are routed a little different. One pump has its inlet port 90 degrees to the arm and the other is in line. Just match to what yours is now.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 2003 Inca Gold TJ Rubicon
2012 JKUR RHD
only in a jeep cj is offline
post #3 of 9 Old 01-29-2019, 07:29 AM
levicj7
levicj7's Avatar
1976 CJ7
I also believe that pre 76 the ports come out the bottom. 76 and later out the top.
PaulLeviCJ7
levicj7 is offline
post #4 of 9 Old 01-29-2019, 12:36 PM
EricRThompson
1979 CJ7
I have a '79 with a 304 and it came with a pump with fittings on the bottom. I've purchased 3 pumps as replacement and cannot find the hard line that goes from the pump to the carb. Anyone know where to source it? I've ordered 3 lines from Quadratec and not one will fit the pump with fittings on the top.
EricRThompson is offline
post #5 of 9 Old 02-01-2019, 10:02 PM Thread Starter
MarkVMod0
MarkVMod0's Avatar
1976 CJ5
That helps guys! I can fabricate a fuel line if I can't find one at the local parts bin.
Mike
post #6 of 9 Old 02-02-2019, 01:41 AM
82JeepCJ7
1982 CJ7
Found a pic of mine when I was building it.
MarkVMod0 likes this.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #7 of 9 Old 02-02-2019, 07:49 PM Thread Starter
MarkVMod0
MarkVMod0's Avatar
1976 CJ5
Awesome picture. Thanks mucho,
Mike
post #8 of 9 Old 06-21-2021, 03:15 PM
vorterxcj5
1963 CJ5
Thought I had this fuel pump straight in my mind but. It appears from reading that on a amx 304 . .The outlets can be at 12 or 6.
My 86 cj7 got its engine from a ? Jeep. When I first took it off I could have sworn the fuel connect was at 12 cause I wanted to attempt (unsuccessfully)removing the lines while the engine held the pump. I also recall being unable to visualize the lines as they were under the pump ? I'm also 2nd guessing which of the different length screws go on the left of right. I'm thinking the shorter goes on right side? TIA
sorry if this a sore subject, but I gots to know
vorterxcj5 is offline
post #9 of 9 Old 06-22-2021, 06:35 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
This is the style pump that was used on Jeeps.
AMC cars with V8s used the style with the fuel line connections on the bottom.
The hard line from the pump to filter can be found here.
I don't recall the bolts being different sizes on mine.
Matt
Matt1981CJ7 is offline
Adjustable FPR and cross flow fuel rail on the cheap Cobra Jeep YJ Wrangler Technical Forum 6 12-30-2018 07:22 AM
Almost stall on stops when engine is hot. High LTFT dynamiccast WJ Grand Cherokee Forum 3 12-07-2018 12:11 PM
Help, my wife put gas in our CRD by mistake Zroe89 WK Grand Cherokee & XK Commander Forum 26 11-09-2018 04:34 PM
Rough idle and hard start Nevsky XJ Cherokee Technical Forum 5 08-31-2018 07:40 PM
New Fuel Pump Not Pumping Fuel D3M0N60D WK Grand Cherokee & XK Commander Forum 4 05-20-2018 08:30 PM
