AMC 258 Oil Filter Sizes (are they interchangeable?) - JeepForum.com
 4Likes
  • 1 Post By oldschool74cj5
  • 1 Post By HoDad
  • 1 Post By Tinker0000
  • 1 Post By JEEPFELLER
post #1 of 14 Old 02-11-2021, 12:50 PM Thread Starter
verreaul
verreaul's Avatar
1976 CJ7
I noticed you can obtain 2 different oil filter sizes for an AMC 258 depending on the year.
Older models use a larger diameter filter (like a WIX 51258 3.66"diameter) and the newer models use a smaller diameter filter (like a WIX51522 2.9"diameter).
I always used the larger diameter filter on mine but mistakenly ordered a few smaller diameter filters a while back.
(I have a 76 CJ7 with an early 80's drivetrain).
I'm too late to return them and was wondering if I could use them.
I have not compared them side by side yet to see if the housing/mating areas are the same.
Just wondering if someone knows offhand if they are interchangeable.
If not, I'll just order the larger filter before I do my next oil change.
Thanks
John
verreaul is offline
post #2 of 14 Old 02-11-2021, 06:14 PM
oldschool74cj5
hello
i really dont think it matters as long as the threads and the gasket diameter is the same.
oldschool
NormWild likes this.
oldschool74cj5 is offline
post #3 of 14 Old 02-11-2021, 07:01 PM
JEEPFELLER
JEEPFELLER's Avatar
1977 CJ5
I always use a Fram PH25 for my CJ-5s since forever ago. (Well, since 1981 anyway)
This was one of the mainstays that got spit out when any Parts store book or computer had my Jeep's info was submitted into it.
Then kinda all of a sudden for some reason no one carried them in their inventory. I used to get them even cheaper at Walmart.
Anymore, a same size different brand ain't in inventory.
Check this out......I decided in the beginning, when I could not get one "now".....I'd have them cross reference the PH25 to another brand.....BAM! got one!.....I watched them cross it (I had it crossed in another store later on)!
I do not recall the brand(s) or numbers, it was the same size can, I even screwed it up on there and fired up the engine. Immediately, oil shot out from around it and I shut it down.
Beings that I had already trashed the PH25, I never compared the gasket circumference with the imposter oil filter.............I fished it out of the trash and found the imposter's gasket was a width larger and was barely touching the seal surface of my engine block.
Lesson learned (many times over again), Compare any Jeep part to the old one, before you dive in!
There has been a time or two that I bowed down and used the smaller filter that they looked up.....It did fit.....But I still did not like it.
I now order and buy 2 or 3 PH25s at a time from the parts store so that I always will have one on hand.
-----JEEPFELLER
JEEPFELLER is online now
post #4 of 14 Old 02-11-2021, 07:23 PM
LumpyGrits
More than once on 'ruff' trails I've seen the larger OD filters punctured by the engine mount.
My '85 came with the smaller diameter filter and have use such since 1985.
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #5 of 14 Old 02-12-2021, 07:41 AM
cjoffroad
cjoffroad's Avatar
1980 CJ7
Thanks
John
Wix 51258 fits the V8. Wix 51522 fits the I6. Since a '76 could have had the V8 or the I6 engines, it's more likely you just selected the wrong parameters when you ordered. The threads should match but I believe you will have issues with the Wix 51258 gasket matching up to the sealing surface of your 258.
Edit: Just re-read your post and seems you've already been using the larger 51258 filter?
Screen Shot 2021-02-12 at 9.59.49 AM.jpg   Screen Shot 2021-02-12 at 9.59.05 AM.png
cjoffroad is offline
post #6 of 14 Old 02-12-2021, 03:49 PM Thread Starter
verreaul
verreaul's Avatar
1976 CJ7
I can see from the WIX specs above that the inner and outer gasket diameters are very close for both filters.
Trivial, but does anyone know if the oil filter housings on the older/newer motors are same/different?
John
verreaul is offline
post #7 of 14 Old 02-12-2021, 04:56 PM
Hurricane4
Hurricane4's Avatar
1979 CJ5
I can confirm the 51258 filter is used on the 304 V8. This is the oil filter I purchase for the 304 in my '79 CJ5:
https://www.summitracing.com/parts/wix-51258
Don't know if the oil filter housing on older/newer engines are same/different.
"The unbelievable we can do immediately . . . the impossible just takes a little longer."
My College Accounting Professor
"Success is not final. Failure is not fatal. It is the courage to continue that counts"
Winston Churchill
Jeeps I Have Owned in Year Order:
'61 CJ5, '63 CJ6, '78 CJ5, '79 CJ5 (Current), '79 CJ7 & '86 CJ7.
Hurricane4 is offline
post #8 of 14 Old 02-12-2021, 05:23 PM
Joncure
Joncure's Avatar
There are some archived posts here that discuss this in greater detail. At some point, the I6 blocks were manufactured without the pressure bypass valve (where filter screws on) because newer generation oil filters were being made with pressure bypass valves inside the filters.
Joncure is offline
post #9 of 14 Old 02-12-2021, 06:45 PM
cjoffroad
cjoffroad's Avatar
1980 CJ7
This change occurred in 1987 for the 4.2L and 4.0L blocks going forward to utilize the in-filter bypass. The thread size also changed to metric.
In 1991 it changed again for the 4.0L after the 4.2L was phased out.
post #10 of 14 Old 02-12-2021, 09:25 PM
HoDad
1981 CJ5
I have a rebuilt '79 258 in my 1981 Jeep. I've been using a Wix 51258 for the past 12 years. No fit or leak problems at all.
cjoffroad likes this.
HoDad is offline
post #11 of 14 Old 02-13-2021, 03:07 PM
Tinker0000
Cool thing about the internet, there is an awesome website that automatically crosses an oil filter so you can find it elsewhere. https://www.oilfilter-crossreference...vert/Fram/PH25
1984 Jeep CJ7 258 Spring Special edition.
Tinker0000 is offline
post #12 of 14 Old 02-16-2021, 08:06 PM
PhillyDak
PhillyDak's Avatar
Thanks. Good info.
Don't tread on me!
PhillyDak is online now
post #13 of 14 Old 02-21-2021, 07:32 PM
Jgnobles
Thanks I was looking for this also
Jgnobles is offline
post #14 of 14 Old 02-22-2021, 09:29 AM
JEEPFELLER
JEEPFELLER's Avatar
1977 CJ5
Check out my "post 3" above!
I used the link Tinker0000 posted and began to see if I could find a filter in which the specs did not match.....Pretty much they don't show the specs for the crossed to filters (which
makes no sense to me).
I rely on "CROSS" to be an exact duplicate of what I don't have....Just in another brand......Or IN AN EXTREME SITUATION, "a different CAN SIZE" with the same exact
"MOUNTING" characteristics as the one I that I cannot find......to me, this works just fine.
I've already spent some time looking in this link above.
I'm not saying that many of these are wrong crosses.
But sure as the world, If I were in a hurry and did not compare old with new, I would get the wrong animal again!
This is sorta how they WEASEL out of providing a correct perfect match in that link with just this one filter I crossed.....It still may be a a guessing game! Wasted time out the
counter (threads sizes would slow me way down---or finding out 20 miles away, in your driveway would be a real pizzer) See pic below
Again, it's best to have extra of the right thing in your stock at home....ahead of time!
To add a little more icing on the cake!
Any part---no matter what---especially a "CORE"----Never surrender it to them, until the new part is installed and proven to work correctly (the $$$ you think you need NOW will
mean nothing, if you received a part
that is not the same as what you started with.
You might spend (up to forever) of your time searching for that SPECIAL AND UNIQUE THING that you can no longer have to compare to......it's gone forever!
-----JEEPFELLER
