AMC 20 Disc Brake Conversion Connection Question - JeepForum.com
 1Likes
post #1 of 20 Old 05-12-2019, 08:37 AM Thread Starter
topherbarrow
Hey All,
I've been working to rebuild the AMC 20 under my 81' CJ7. One of the things I've been working on was the disc brake upgrade. I ordered all parts outlined in this thread, and i've got it all bolted up. However, when connecting the calipers to new brake lines I purchased, the connector seems to be too shallow for the flared tubing to seal the connection.
I took a quick video
, and I wanted to see if anyone has run into this issue before.
Thanks in advance,
Topher
topherbarrow is offline
post #2 of 20 Old 05-12-2019, 01:05 PM
skizriz
skizriz's Avatar
1978 CJ7
I'm guessing the caliper takes a bubble flare, and your CJ lines are a standard double flare end.
You can get adapters, or a line with the proper ends.
http://www.fedhillusa.com/?page=flare
skizriz is offline
post #3 of 20 Old 05-12-2019, 03:01 PM
Ollie09
1977 CJ5
Or it uses a banjo fitting.
Ollie09 is offline
post #4 of 20 Old 05-12-2019, 09:43 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
Did you buy the brake hoses for a 300z?
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #5 of 20 Old 05-13-2019, 08:59 AM Thread Starter
topherbarrow
@skizriz , thanks for that link and info! This will be very helpful in the future.
@BagusJeep , I did not purchase 300z lines. I purchased the direct replacement for my CJ. I can only assume that because I purchased my calipers new, they didn't include the rubber hose that connects directly to the CJ lines.
I will research an adapter. If anyone has done this before and can save me some time, please let me know.
Thanks,
Topher
post #6 of 20 Old 05-13-2019, 09:10 AM
Fourtrail
1974 CJ6
Order the correct rubber lines for the 300z calipers. no fun to take the hard line loose and re-bleed every time you need to change brake pads, plus with a floating caliper, you will work harden/bend your metal lines every time you push on the brake pedal. You will also need to shorten and re-flare the hard lines and then you can add the clip to the axle housing to hold the hard line end of the rubber line in place.
https://www.speedwaymotors.com/shop/...rake+line+clip
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #7 of 20 Old 05-13-2019, 10:24 AM
skizriz
skizriz's Avatar
1978 CJ7
I didn't even notice the lack of rubber line.
skizriz is offline
post #8 of 20 Old 05-14-2019, 04:00 PM
BrutusBlue
1982 CJ7
Make a couple of the small hose brackets like you see in the box beside the caliper brackets. I made an extra set years ago in the event I do another one.
BrutusBlue is offline
post #9 of 20 Old 05-15-2019, 08:59 AM
ddawg16
ddawg16's Avatar
Brutus...I'm doing the same conversion...but I didn't buy the kit. Where did you get your brackets? Non of the old sources seem to be active any more.
ddawg16 is offline
post #10 of 20 Old 05-16-2019, 07:07 AM
BrutusBlue
1982 CJ7
They are one offs. I took the pattern to a local company that does all sorts of cuts for industrial work. They were nice enough to cut out two sets for me at no charge. I think the engineer was a jeeper who was happy to have something different and less boring to scan and make. I can’t remember which forum or member I pulled the image from but there are several workable versions available.
I was going to cut some myself but got real lucky in finding the place. The caliper brackets were cut from 3/8 and the hose brackets were cut from 1/8.
post #11 of 20 Old 05-16-2019, 09:31 AM
ddawg16
ddawg16's Avatar
Do you still have the dxf file?
ddawg16 is offline
post #12 of 20 Old 05-16-2019, 09:26 PM
BrutusBlue
1982 CJ7
No. It’s been 7 or 8 years at least since then...you should be able to pic an image with a point A to B reference or some sort of measurement in order to correctly proportion for CAD. If I recall they simply scanned the best of several images I took to them.
ddawg16 likes this.
post #13 of 20 Old 11-24-2019, 08:45 PM
rtorres
1972 CJ5
How you guys figure out how to connect the ebrake cable? I'm not see how to make it work.
Sent from my SM-G960U using Tapatalk
rtorres is offline
post #14 of 20 Old 11-24-2019, 08:54 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
Do you have pictures? Are you using the 300Z rear caliper?
post #15 of 20 Old 11-25-2019, 10:20 AM
rtorres
1972 CJ5
I used the Nissan maxima calipers. I believe are the same as 300z. I need to attach the e brake cable on that level. I circle the level. I have the original e bracket for.the calipers, but I can't use it is too low and interfere with the differential.
rtorres is offline
Dual diaphragm brake booster kit question Cutlass327 Jeep CJ Forum 9 04-30-2020 09:23 AM
brake master cylinder pushrod question clarkg Jeep CJ Forum 9 02-10-2018 01:14 PM
78 cj7 brake question hrowzie Jeep CJ Forum 0 01-28-2018 09:36 PM
Parking brake opinions Waternut YJ Wrangler Technical Forum 16 01-17-2018 07:55 PM
E Brake axle swap question mediumdaddy TJ Wrangler Technical Forum 3 12-30-2017 10:20 PM
