amc 20 axle replacement manual - JeepForum.com
post #1 of 2 Old 02-04-2009, 04:12 PM Thread Starter
armedsks
2009 JK Wrangler
I have bearings and seals on the way to fix the rear axle slop and leak. The PO allready put in the one piece axle's (alloy usa) but didnt put the bearings in right. Is there a instruction manual on the web that goes over how and put the bearings and seals the correct way??
armedsks is offline
post #2 of 2 Old 02-04-2009, 04:19 PM
Bard
These are for Mosers, but should be somewhat close. I am sure someone has your brand on here.
[IMG][/IMG]
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline
AMC 20 axle replacement. I'm looking for ideas. cowdodger1 Jeep CJ Forum 13 01-24-2010 11:03 PM
Rear Axle Seal Replacement 84 CJ7 Jeep CJ Forum 7 06-09-2008 03:30 PM
Axle shaft U joint replacement HELP! xj89 Jeep CJ Forum 25 11-14-2007 06:53 AM
New Gears or Axle Replacement???? 84-CJ Jeep CJ Forum 6 09-16-2007 09:22 AM
axle bearings and seal replacement for D44 Blackjackbender Jeep CJ Forum 4 11-19-2005 04:55 PM
