Alarm to Air Horns? Which Relay Fasher? - JeepForum.com
 2Likes
post #1 of 34 Old 07-29-2020, 11:15 PM Thread Starter
258
Cj Alarm to Air Horns? Which Relay Fasher?
Folks, I connected my loud air horns to my alarm but I can not get the horns to sound flash (go on and off) with the alarm; meaning, they simply stay on constantly. I purchased an electronic flasher but it's not working. So, maybe I got the wrong one? Has anybody done this and if so, which flasher relay did you use? It is a 2 prong relay flasher and I was told there is a specific one I need however. Don't know for sure which one I need. Any thoughts?
258 is offline
post #2 of 34 Old 07-30-2020, 04:50 AM
BagusJeep
BagusJeep's Avatar
1981 CJ7
How are you actuating the air horn compressor? They take quite a load and should be run through a relay. If you do not you will be fighting the high resistance and amperage with your car alarm which was not designed for it.
If your alarm was designed to actuate a normal car horn up and down, it was about 5 Amps. The compressor draws 15 Amps. You need a relay in between.
By contrast a 21W indicator lamp is around 1.5 Amps. that is why a flasher relay will be hard to find that is matched to the compressor. They are often "load sensitive" and will flash faster if the designed number of lamps (or equivalent load) are not connected.
if you have a constant alarm signal and want to make it go on and off, again use a relay to power the flasher relay and then the compressor.
An electro-mechanical type flasher is suitable to actuate the compressor as it does not care what amps you need, and does not detect a broken lamp. You can also use an electronic flasher as long as it is clearly labelled as non-load sensitive. Needless to say both need to be able to handle the load.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #3 of 34 Old 07-30-2020, 12:23 PM Thread Starter
258
Cj
The air horns run on a relay to their compressor. They have been set up nicely for many years. They are LOUD!
Yes, I am finding the relay flasher that accommodates it really hard to find.
It is set up with a FLASHER to make it go ON and OFF but again, it is not doing it. My guess; the FLASHER. Air horns go ON when alarm is triggered but with all sirens, air horns still stays CONSTANT!
I bought the Electro-Mechanical flasher (Osram - LF12) and there is no ON and OFF!
So, currently there are 2 relays on the system but I was told by alarm shop that it needs the CORRECT relay flasher, otherwise it will be CONSTANT. I need that Brand and part number.
258 is offline
post #4 of 34 Old 07-30-2020, 11:57 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
Looking at the LF12 it is electro mechanical.
So the LF12 is not turning on and off? Have you checked this with a multimeter and a simulated load such as a bulb?
12 Volt applications
2 terminals (X, L)
1 to 10 lamps (240 Watt / 20 Amp)
5 times louder than thermal flashers
Must fuse X lead
For car/truck trailering
You could try the EL13 but I woud be surprised at an elecr0-mechanical flasher not turning on and off.
post #5 of 34 Old 07-31-2020, 02:01 PM
JEEPFELLER
JEEPFELLER's Avatar
1977 CJ5
I'm not following relaying at the compressor?
It would make more sense to run a flasher (or whatever) with 12 volts feeding into the horn switch wire and "off and on" the solenoid.
-----JEEPFELLER
JEEPFELLER is offline
post #6 of 34 Old 07-31-2020, 03:59 PM
Fourtrail
1974 CJ6
The alarm system puts out a positive signal, so using a relay at the compressor to supply a ground and turn it on/off as the horn button creates the ground side of the horn loop, not the power side. OP, sounds like the low amp draw of the relay is not enough to get the electro-mechanical relay to break over and flash. You likely need a low draw flasher like what is used when converting to led's.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #7 of 34 Old 07-31-2020, 04:08 PM
Fourtrail
1974 CJ6
-----JEEPFELLER
wire from the horn is a ground, not 12v, hence the relay to provide a ground
post #8 of 34 Old 07-31-2020, 06:31 PM Thread Starter
258
Cj
-----JEEPFELLER
Where is it attached to an alarm? My air-horns work fine, simply need to configure the CORRECT relay hook-up for the alarm to air-horns.
258 is offline
post #9 of 34 Old 07-31-2020, 06:34 PM Thread Starter
258
I thought Elctro-Magnetic relay was for LED conversions? Hmmm? I will go back and take a look. I bet it's something super easy, lol. Thanks
258 is offline
post #10 of 34 Old 07-31-2020, 09:16 PM
John Strenk
John Strenk's Avatar
1976 CJ5
They are and work with the low current draw from the LED.
But a relay is really low power and may not be enough to start it flashing.
Are you trying to do something like this
https://www.the12volt.com/relays/ill...-flash.asp#lf3
Why didn’t they tell you what one to use.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #11 of 34 Old 08-01-2020, 04:34 PM Thread Starter
258
Your link is not working . . . They seemed to be out of any but I was asked to return Monday to get it dialed in correctly since the Electro-Magnetic one failed to perform.
258 is offline
post #12 of 34 Old 08-01-2020, 04:51 PM Thread Starter
258
This is the air horn set up. The bottom relay (below the 2) is the original relay for air horns and it gave NORMAL performance. Push the horn button at steering wheel and it would blow air horns; simple!
The TOP relay set-up is the newly added relays. One to alarm, other to air horn compressor relay. The yellow relay is the newly installed Electro-Magnetic relay. So yeah, I'm missing something here, lol.
258 is offline
post #13 of 34 Old 08-01-2020, 06:41 PM
John Strenk
1976 CJ5
Do you have it wired up something like one of these?
uptillnow likes this.
post #14 of 34 Old 08-01-2020, 07:25 PM
CSP
Flashers require resistance to get them to break contact and resume contact. Relays require milliamps to trigger them. Not enough resistance there to make the flasher work. You need an electronic flasher, available at any auto parts store. Find one with the same blade pattern as your existing flasher.
CSP is offline
post #15 of 34 Old 08-02-2020, 05:23 PM Thread Starter
258
Cj
Yes, initial set-up is like your diagram. The difference now is the alarm addition and the air-horn connection.
258 is offline
