Air filter for Howell fuel injection - JeepForum.com
 2Likes
post #1 of 26 Old 01-16-2020, 07:49 AM Thread Starter
scubajt
scubajt's Avatar
Hey guy’s what air filters are you using on your Howell fuel injection systems? I can’t use the 10 inch they recommend because of the power brake system. Looking for some suggestions. Thanks
scubajt is offline
post #2 of 26 Old 01-16-2020, 09:13 AM
cdt540
1983 CJ7
I have a MC2100 and power brakes on mine. The stock air filter designed for power brake CJs won't fit on a MC2100. So I had to go with a cheesy CAI to get around the size issue. I took some ribbing when I posted pics of it. Took a bit to convince them that I know I was not getting cold air and I know it is was not creating more HP. It was just a cheap and easy fix to find a air filter that would fit my setup.
Cutlass327 likes this.
Chris
'83 CJ7 (258 5 spd)
Austin, TX
cdt540 is offline
post #3 of 26 Old 01-16-2020, 09:31 AM
DougE
1983 CJ7
Summit Racing has offset air cleaner bases. They move a 14" filter 1-1/2" so the distance from the center of the carb to the edge of the filter housing is 5-1/2". Maybe this could work for you?
1983 CJ7, 258I6, T4, Dana 300, 31x10.5x15 DuraTrac
DougE is offline
post #4 of 26 Old 01-16-2020, 11:28 AM
beavis83cj7
Junior Member
1983 CJ7
I used the K&N 9 inch and I have power brakes. Clearance is fine. I'll get a picture tonight if you want it.
https://www.jegs.com/i/K%26N/599/60-...iABEgJbQ_D_BwE
beavis83cj7 is offline
post #5 of 26 Old 01-16-2020, 01:20 PM
80cj
80cj's Avatar
1980 CJ5
How big is the air cleaner base on the Howell/GM TBI?
80cj is offline
post #6 of 26 Old 01-16-2020, 04:56 PM
jlkeener
1980 CJ5
I fitted the stock air cleaner on My 1980 304. Not sure if Howell uses the same throttle body for the 258. It matched up really good.
jlkeener is offline
post #7 of 26 Old 01-16-2020, 05:52 PM
80cj
80cj's Avatar
1980 CJ5
So probably same as Holley four barrel.
80cj is offline
post #8 of 26 Old 01-16-2020, 07:05 PM Thread Starter
scubajt
scubajt's Avatar
That would be great I would appreciate a picture. Thank you
scubajt is offline
post #9 of 26 Old 01-16-2020, 07:08 PM Thread Starter
scubajt
scubajt's Avatar
It measures 5 1/8 inches.
scubajt is offline
post #10 of 26 Old 01-16-2020, 07:21 PM
beavis83cj7
Junior Member
1983 CJ7
Sure thing. Here you go. Pay no attention to the zip ties on the wiring! I just put in a new harness and haven’t loomed it up yet.
6B778858-81A7-4C35-9586-C7988717E743_1579224029153.jpg   F2ADFDC3-08DC-42DC-853E-3CD0AF7B8956_1579224063255.jpg   3A06FA8E-5E4B-46A5-89FB-3C24466DFCA2_1579224082341.jpg
post #11 of 26 Old 01-16-2020, 10:36 PM
Axhammer
Axhammer's Avatar
I put a 9” filter on mine, it has a 5 1/8” base, same as a four barrel (holley or Q-jet). I guess a larger diameter would have worked since I have manual brakes, but it’s only a 110 HP 258 CID motor, it’s not like it moves a lot of air.
1985 CJ-7 Red with white hardtop, 258 auto
View my Pontiac in my profile
Axhammer is offline
post #12 of 26 Old 01-17-2020, 07:25 AM Thread Starter
scubajt
scubajt's Avatar
Thanks for the pictures, I judge no one and there wiring.LOL
scubajt is offline
post #13 of 26 Old 01-17-2020, 07:44 AM Thread Starter
scubajt
scubajt's Avatar
Thanks guys for all the responses,now to figure out what one will work best.
scubajt is offline
post #14 of 26 Old 01-17-2020, 10:49 PM
Timaaaay83
1983 CJ7
Looks identical to mine with manual brakes. Should be plenty of room with the brake booster.
Timaaaay83 is offline
post #15 of 26 Old 01-18-2020, 08:32 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I'd use one of these, with the original air cleaner assembly before going to an open element type.
Matt
STJP likes this.
Matt1981CJ7 is offline
