86 D44 vs AMC20 vs newer D44 - brake questions - JeepForum.com
 1Likes
  • 1 Post By Rondawg80
post #1 of 2 Old 08-01-2020, 09:36 PM Thread Starter
Cutlass327
Cutlass327's Avatar
1978 CJ5
Just how much is different? Can the backing plates from a AMC20 fit a D44?
Reasoning behind this question:
I want to bolt on factory disk brakes, or a kit that uses factory style pads, rotors, calipers. MUST have an e-brake.
I have seen weld-on brackets, but normally they are set up for Caddy calipers with the e-brake in them. I like the drum-in-hat design.
Would a rear disk setup from a Grand Cherokee D44 bolt on?
I know Tracker rotors are proper bolt-on fit, would they fit any of these setups?
Rick
Cutlass327 is offline
post #2 of 2 Old 08-02-2020, 05:05 PM
Rondawg80
1980 CJ5
I swapped my model 20 for a 73 Jeepster Dana 44, the brakes on my 20 were ALL NEW. I just took the plate off with all the brake hardware and it bolted right up to my Dana 44! My 20 was from a 78 CJ with 11" brakes. It literally was a direct fit. I don't know about the disk setups.
Cutlass327 likes this.
Rondawg80 is offline
