86 cj7 oil pressure sending unit / guage - JeepForum.com
 3Likes
post #1 of 42 Old 04-02-2020, 08:13 PM Thread Starter
cj7jeepin
cj7jeepin's Avatar
The original engine was the 4 banger . It has a 258 from a yj now. Finally got it running today after a lot of work wiring Howell tbi exhaust etc. the oil pressure pegs 80 in the run position but as soon as you start it it drops to 0 . Do I have no oil pressure or is somthing wrong? I grounded the the wire off of the sending unit and it jumps to 80. Thanks in advance
cj7jeepin is offline
post #2 of 42 Old 04-03-2020, 12:58 AM
BagusJeep
BagusJeep's Avatar
1981 CJ7
Sounds like the sensor is faulty. It is grounded at 0 pressure and then flakes out when it has any pressure. By grounding it you have verified the wiring. I sit possible you have a pressure switch and not a sender? The switch closes below 4psi and would give you these symptoms.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #3 of 42 Old 04-03-2020, 04:12 AM Thread Starter
cj7jeepin
cj7jeepin's Avatar
I was under the assumption I had both . It’s hard to see in this picture so let me know if I need to take a better one.
post #4 of 42 Old 04-03-2020, 05:39 AM
bob4703
1974 CJ5
You could have a mismatched gauge and sending unit if you are using the sender that came on the engine and the original gauge.
Paved roads are prime examples of government over spending!
bob4703 is offline
post #5 of 42 Old 04-03-2020, 05:49 AM Thread Starter
cj7jeepin
cj7jeepin's Avatar
I thought abt that after reading some posts. So I took the one off of the 4 banger and tried it and had nothing. No signal at all.
post #6 of 42 Old 04-03-2020, 06:08 AM
bob4703
1974 CJ5
Have you thought about tossing all and going with a mechanical gauge? IMHO mechanical is more accurate and less expensive. I replaced my 45 year old electric gauge and sending unit with a mechanical for less than the cost of a new sender.
bob4703 is offline
post #7 of 42 Old 04-03-2020, 06:35 AM
John Strenk
John Strenk's Avatar
1976 CJ5
YJ oil pressure resistance :
PSI .................................................. .......................Ohms
0 .................................................. ............................1
40 .................................................. .......................... 37
80 .................................................. .......................... 89
CJ Oil Pressure resistance [2"]
PSI..................... Measured Ohms............................. spec chart ohms
0......................... 239.............................................. 227-257
5......................... 239............................................... 146-219
40....................... 108............................................... 83-123
80....................... 40................................................ 22-51
or
CJ Oil Pressure resistance [1"]
0-4................................................. .............................. open
33................................................ ................................ 20-32
63................................................ ................................ 13-25
90................................................ ................................. 9-17
(tip of the hat to Fjguercio for the chart)
So it's completely backwards for a CJ oil pressure gauge.
Yeah it won't work. Hopefully you haven't damaged your gauge.
More Oil pressure sending unit info:
https://www.jeepforum.com/forum/f8/c...-depth-920751/
or
This post actually has some part numbers:
https://www.jeepforum.com/forum/f8/c...essure-741622/
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #8 of 42 Old 04-03-2020, 07:02 AM Thread Starter
cj7jeepin
cj7jeepin's Avatar
I ordered a sending unit for a Cj would that remedy the situation assuming the guage is still fine? Thanks for all the help
post #9 of 42 Old 04-04-2020, 01:47 AM Thread Starter
cj7jeepin
cj7jeepin's Avatar
So I got the sending unit from o Reilly’s , I’ll have to double check the part number. Issue is that now I have a zero ohm reading when i check across the post to ground. But when the car is running I get a steady 40 psi at abt 2000 rpm (haven’t properly set up the Howell yet) . Does this sound correct?
post #10 of 42 Old 04-04-2020, 09:10 AM
hodge5
hodge5's Avatar
That's what I did. Simpler, and more accurate.
Mine is putting out 38 PSI at idle, and going up to almost 50 at road speed (I don't have a tach).
hodge5 is offline
post #11 of 42 Old 04-04-2020, 03:18 PM Thread Starter
cj7jeepin
cj7jeepin's Avatar
I’d rather keep the oem stuff if its all working. I just don’t understand why there is no resistance on the sender . The old one I had on the 4 cyl did the same thing but was dead and didn’t read anything while running. This one seems to read I just don’t know if it’s the right sender or accurate because I can’t get any resistance.
post #12 of 42 Old 04-04-2020, 06:58 PM
John Strenk
1976 CJ5
0 ohms or Infinite Ohms
Makes a difference
0 ohms is a dead short
Infinite ohms is an open.
post #13 of 42 Old 04-05-2020, 03:11 AM
keith460
keith460's Avatar
And you should since they are unique to the CJ dash. You can always adapt a small liquid filled pressure gauge to the existing sending unit and pressure switch union fitting on the side of the block and have the best of both worlds.
cjoffroad and weapon like this.
1984 CJ-7 Renegade
keith460 is offline
post #14 of 42 Old 04-05-2020, 03:18 AM Thread Starter
cj7jeepin
cj7jeepin's Avatar
Honestly I’m not super great with multimeters , just enough to get by. I assume it’s infinite . It does not say 0 it has a 1 on the left side . Same as if I were touching nothing at all.
post #15 of 42 Old 04-05-2020, 03:19 AM Thread Starter
cj7jeepin
cj7jeepin's Avatar
I double checked the guage tonight as well and it’s kinda surging between 40 and 50 psi at roughly 2000 rpms .
