‘86 2.5l manual carb question - JeepForum.com
 3Likes
  • 1 Post By BagusJeep
  • 1 Post By John Strenk
post #1 of 11 Old 07-22-2019, 07:56 PM Thread Starter
brian.donald
brian.donald's Avatar
Jeep newbie here. So I’m going to the nutter and want to switch out the carb to a non-electric choke carb. What is the best setup? I saw the k552 but that appears to have a computerized choke.
1986 CJ7 4cyl stock (for now)
brian.donald is offline
post #2 of 11 Old 07-22-2019, 11:17 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
32/36 dgv is manual choke version
the dgev is electric choke. you hook it up with 12V power through the oil pressure switch and then you need not bother again, unless it goes out of adjustment.
pedal2themetai likes this.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #3 of 11 Old 07-23-2019, 02:23 AM Thread Starter
brian.donald
Thanks for the reply... I looked that carb up and everything says 4.2l Jeep. Mine is a 2.5l. Before I order one I just want to double check that it is compatible with my motor
post #4 of 11 Old 07-23-2019, 10:43 AM
uptillnow
uptillnow's Avatar
I was just checking on this and find that the K552 is an electric choke (32/36 DGEV).
The K553 is the same, although a manual choke (32/36 DGV).
This is not a computerized choke, just a switched/keyed 12 volt source to the choke.
I highly recommend the electric choke. They work great and last a long time.
The manual choke, "cable" is twisted wires, and after pushing and pulling the strands start unraveling and begins to stick inside the outer sheathing. They don't pull the choke off all the way and don't push in smoothly after a while.
UTN
uptillnow is offline
post #5 of 11 Old 07-24-2019, 08:33 AM
pedal2themetai
1956 CJ5
UTN
Hi, AAAHHH Not.. if your choke cable is twisted wires then you have the wrong cable.. a choke cable should be a solid wire cable..
good luck
tim
pedal2themetai is offline
post #6 of 11 Old 07-24-2019, 11:45 AM
uptillnow
uptillnow's Avatar
good luck
tim
Tim,
It does sound like you've seen some choke cables in many vehicles.
And I agree that the "Morse" solid push pull cable is absolutely better than the twist cable used as a push pull. (solid push pull used in most all Marine applications)
The auto parts store I work at sells about 2100 of these twisted choke cables a year. These sales are very consistent from year to year. This is where my information comes from, I am saying the majority of the choke cables are twisted wire and don't last very long, (year or two).
"Good Luck"
UTN
$38.00 for a solid push pull
https://www.zoro.com/buyers-products...xoC-zQQAvD_BwE
post #7 of 11 Old 07-24-2019, 12:43 PM
John Strenk
John Strenk's Avatar
1976 CJ5
UTN
good luck
tim
Tim,
"Good Luck"
UTN
If you had two of these cables hooked up, it would work just fine. one to pull open, one to pull shut, both connected at the same point.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #8 of 11 Old 07-24-2019, 01:31 PM
BootheelBoy
I did the exact same thing to my 86 with 4 cylinder about 15 years ago. My Jeep has a Carter YFA carburetor on it from the factory. I kept the same carb and replaced the electric choke with a kit to change it manually. It has the coiled wire with cable inside. It is still working fine after all these years. The push/pull is mounted under the dash in line with the fan and heat knobs. As far a nuttering it mine didn’t have the stepper pins in the carb. All I had to do was run wires from the control module on the drivers side fender under the windshield washer reservoir to the distributor. It helped smooth out the engine. Shortly after doing that I replaced my old vacuum lines and simplified them down to the bare essentials. I can’t remember if I had to set the engine timing any different.
BootheelBoy is offline
post #9 of 11 Old 07-24-2019, 11:52 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
The 32/36 carb is the right size for a 2.5l, a bit small for a 4.2 but it has a more pronounced vacuum signature I understand which makes it more responsive and economical at low engine seeds (the 4.2 is not a revvy thing, it is long stroke) so suits some owners of the 4.2.
The question you need to ask is whether you need a manifold adapter and if so, which one (sorry, i do not have a 2.5 so have never attempted this) . They should be different for a 2.5 that had a single choke carb than a 258 with a twin choke so the kit numbers are probably not the same. Drop Redline a question and they are reputed to be helpful.
post #10 of 11 Old 07-25-2019, 04:52 AM
John Strenk
1976 CJ5
Since it is a YF style carb, The Weber adapter that fits the 4.2 with the YF should also fit on the 2.5 with the YFA.
uptillnow likes this.
post #11 of 11 Old 07-25-2019, 11:29 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
John, good point.
When I started buying the Weber 38s I could not get a Redline kit without heavy import duties so I investigated the spacing of the bolts etc with an Australian supplier (free trade agreement with Aus) as there was no specific adapter listed in Aus. He came up with a Stromberg adapter plate (stromberg one side, Weber 38 other side) which came in a Redline packet but I have been wary of generalising ever since on adapters.
