85 CJ7 Spring Over Axle Swaybar? - JeepForum.com
post #1 of 11 Old 04-20-2012, 03:04 PM Thread Starter
accidentprone
Anyone able to do it? I have a SOA and I'm new to jeeps, and my swaybar is FUBAR. Like its totally broken. Im not looking to go fast in this, I only really need to go 55, so if I can run it without a swaybar, what are recommendations for that? Id really like to not tip over lol. Pics of my current swaybar setup are at the bottom of this thread if it helps.
https://www.jeepforum.com/forum/f8/25...-help-1358617/
accidentprone is offline
post #2 of 11 Old 04-20-2012, 03:27 PM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
I'd be more concerned with your draglink/steering.
I'd also like to know where the caster is at ?
But to answer your question, They make heavy duty off the shelf spring plates with bolt on,screw in studs.
http://www.currieenterprises.com/ces...t.aspx?id=2873
I'd also get a set of quick disconnects while you are at it.
LT1CJ7 is offline
post #3 of 11 Old 04-20-2012, 05:38 PM
82JeepCJ7
1982 CJ7
I built my own short links so the sway bar is kept level.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #4 of 11 Old 04-20-2012, 05:55 PM
Bakunin
Bakunin's Avatar
Don't run it on road without a sway bar. Sure, you can do it, but you sacrifice a lot of safety in the process.
Bakunin is offline
post #5 of 11 Old 04-20-2012, 06:13 PM
skizriz
skizriz's Avatar
1978 CJ7
I simply welded some tabs on to the axle tubes.
Pull out the lynch pin, and the pin slides out releasing the sway bars.
skizriz is offline
post #6 of 11 Old 04-20-2012, 07:30 PM Thread Starter
accidentprone
Cool, you guys rock
post #7 of 11 Old 04-23-2012, 09:35 PM Thread Starter
accidentprone
I ordered the RR spring plates for the right and left hand side, and I was wondering if I rotated my bar up a little, I could create enough distance for these, which seem like a pretty good deal. Please keep in mind that my jeep isnt a dedicated hardcore rock climbing super duper every ounce of my check jeep. Its a budget build kinda thing thats meant to be pure fun.
http://www.ebay.com/itm/260949870433...#ht_500wt_1180
post #8 of 11 Old 04-23-2012, 10:04 PM
jakewalker53
I put my stock plate on top of my perch and made me a new top plate. i also have a 2'' block but you dont need that. you can see here.
jakewalker53 is offline
post #9 of 11 Old 04-24-2012, 05:54 AM
82JeepCJ7
1982 CJ7
^^^ Example of what NOT to do.....
post #10 of 11 Old 04-24-2012, 07:27 AM
MoC
MoC's Avatar
Deleted.. Already being discussed in another post about soa
MoC is offline
post #11 of 11 Old 04-24-2012, 11:11 AM
RobsCrawlin7
no balls
RobsCrawlin7's Avatar
another thing to consider is 1 ton spring plates off a gm, they have a threaded hole on the side and WONT bend like your stock one did. in this pic you can see them, but the threaded hole is on the left side ( i had to swap the plates when i put in new springs) but you get the idea. this picture was taken first thing when i bolted the axles in, so i know there are problems (shocks, front driveshaft, swaybar is upside down) but they are all fixed now
'01 TJ 4.7/NV3550, 2" lift, 35's, locked.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
SSG David Mejias, SSG Eric Vick, SGT William Bowling, SGT Robert McDowell
1 April 2007
Rest In Peace Brothers
RobsCrawlin7 is offline
spring over axle vs. spring under axle? sbcranger Jeep CJ Forum 10 06-29-2015 10:55 AM
Spring over axle? 1slos10 Jeep CJ Forum 10 05-22-2011 05:46 PM
Convert spring over axle to spring under axle jeeptree2112 Jeep CJ Forum 6 08-08-2010 07:27 PM
Leaf spring width for a 73 cj5 and spring over axle burtonboard180 Jeep CJ Forum 1 08-20-2009 08:11 AM
has anyone used the yj leaf spring conversion for a cj and or axle over spring kits? rhino1 Jeep CJ Forum 0 08-11-2004 08:23 PM
