85 CJ7 Radiator - Page 2 - JeepForum.com
 3Likes
post #16 of 35 Old 10-31-2019, 09:57 AM
258
I have the HD one (right on photo) and I also have the Serpentine Belt with the A/C bracket installed; no A/C. Never had a fit issue. As I recall, my installation went as DougE breaks it down.
258 is offline
post #17 of 35 Old 10-31-2019, 10:25 AM
Deer-Slayer_5
Deer-Slayer_5's Avatar
Since this is a topic that is showing up today I figured Id ask here than make a new thread... Do all the radiators come with a built in transmission cooler? I am buying a new one here soon and they have the option but I have a manual trans so it most likely doesn't apply to me. I'm just curious
CJ-7 build
Deer-Slayer_5 is offline
post #18 of 35 Old 11-01-2019, 10:38 AM Thread Starter
Geek
Got It
So I returned my CC583 radiator back to Ledfoot Racing. George there was great in taking it back with no hassle. I sent him pics of the issue and he totally got it. Promised me he would go back to Champion and ask the question. In continuing to look for a replacement, I happened upon another Champion radiator that has the exact same measurements as my stock one. As in exactly the same as the heavy duty version where the filler is on driver's side. It is also spec'd for the 81-86 I4 and I6 Jeep CJ. Called George back and asked about that. Turns out I wasn't the first to send the 583 back and so Champion did some homework and came up with a 'new' radiator that would work with the I6 and a clutch fan. George says it's only been available for a couple weeks so he and I are swapping as we speak.
So for those out there looking for an aluminum radiator, no plastic tank, works with a clutch fan and is pretty reasonably priced, here's the link to the page.
https://www.championradiators.com/product/CC58
Again I really appreciate all the help from those that weighed in.
Geek
Geek is offline
post #19 of 35 Old 11-01-2019, 10:58 AM
258
Geek, you should find out if "CHAMPION" makes that style radiator in a brass version.
258 is offline
post #20 of 35 Old 11-01-2019, 02:10 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Champion makes only aluminum radiators.
Matt
Matt1981CJ7 is offline
post #21 of 35 Old 11-01-2019, 05:49 PM
whollsee
1982 CJ7
Matt
But...copper/brass is better....isn't it?
When ever I hear the word 'Jeep' I reach for my wallet.
whollsee is online now
post #22 of 35 Old 11-02-2019, 05:33 AM
Matt1981CJ7
1981 CJ7
Depends who you talk to, or which article you read. But let's not go there.
Matt
post #23 of 35 Old 11-02-2019, 07:35 AM
ddawg16
ddawg16's Avatar
Matt
It's kinda like the airline issue....iron pipe vs copper pipe vs PVC......it's such a touchy subject on another forum I'm on, you can almost get banned if you bring it up.
But to answer the original question....brass has the advantage of being a being easier to manufacture (way back when) and I'm guessing it's cheaper.
here is a good article on it.
https://wizardcooling.com/blog/brass...al-properties/
MikeyDeezy likes this.
ddawg16 is offline
post #24 of 35 Old 11-02-2019, 07:38 AM
ddawg16
ddawg16's Avatar
Originally Posted by Geek View Post
Yeah I wish I had 5 inches of space. Here's a pic of the fan and in the background you can see it almost perfectly lines up with the flange on the grill where the radiator mounts. The other pic shows the space between the mounting flange and the radiator itself.
258 - Thanks for that pic. Will see if I can find a heavy duty like that one.
Part of your problem is the fan clutch.
You could go flex fan (more noise) and free up about 1-2".
If it was me, I'd be going electric. I have a Ford Taurus fan with a DC variable speed controller. It only runs then fan when needed. I can shut if off when going through water...or turn it on full blast at idle or if the engine is off.
ddawg16 is offline
post #25 of 35 Old 11-05-2019, 08:29 PM
Toms-CJ7
1982 CJ7
I bought a Champion 3 row radiator for my 85 CJ. Stock 4.2L that has a clutch fan. The radiator was recommended here on the forum in a few places but there is no way it will fit (2 or the 3 row) with the clutch fan there. (I looked closer and those who liked this radiator had the V8 and not the 6) So I question if the clutch fan is "stock". The radiator that is on there is offset back into the grill by 1 7/8 inch and the Champion 3 row is only about a quarter of an inch while the 2 row would be about 3/4 of an inch based on the specs.
Anyone have any good suggestions for a radiator when using a clutch fan on the mighty 4.2?
SPOILER ALERT: Go to post #18 for the fix!!!
Thanks
Geek
I know you solved this, however for potential future reference, I had a similar issue when I went to an aluminum radiator and a new fan clutch. My new radiator would not fit with the new clutch which was thicker than the old clutch. I think the difference are thermal and non-thermal clutches and one is thicker than the other. I had to use spacers to push the new deeper radiator (had an additional core over the OEM radiator) back into the grill frame as well as go back to the old clutch. Thankfully my new radiator could be inset some.
Toms-CJ7 is offline
post #26 of 35 Old 11-05-2019, 09:32 PM
andysbarker
andysbarker's Avatar
1980 CJ5
I also switched to an electric fan in 2015. Highly recommend! Use a Ford Contour fan, it fits the Jeep radiator PERFECT! There are forums on this upgrade. I got it from a salvage yard for $20. I’m using it with a 2- row aluminum radiator (Champion EC583JP). 1980 CJ5, 258 engine.
ddawg16 likes this.
Last edited by andysbarker; 11-05-2019 at 09:43 PM. Reason: Added radiator part number
andysbarker is offline
post #27 of 35 Old 11-06-2019, 01:29 PM
cj7efx
My electric fan solution
Attached is the solution I came up with for the three row Champion and a 14 inch 90 watt 2250 rpm electric fan from e-bay. the fan is mounted slightly offset. Coupled with the thermostat, no problems. 1980 CJ7 4.2 with 999 automatic hooked up to Champion's built-in automatic transmission cooler
ddawg16 likes this.
cj7efx is offline
post #28 of 35 Old 05-22-2020, 01:11 PM
43Duc
43Duc's Avatar
1982 CJ8
Bringing up an old thread, but I bought this radiator, the CC58 and today find that it does not fit my 82 Scrambler. The mounting flange is about 1/2" away from making contact. Also the driver side rests on the the power steering lines and keeps the driver's side flange from lining up w/ the bolt holes by about 3/4 to 1". If I drill the flange and mount it high, the radiator cap hits the hood. Needless to say I'm extremely disappointed. I'd love to post some photos, but they are too big to post to the forum and I can't find a host that I can get to work. I have yet to contact Leadfoot Racing about it, but thought I'd post here to see if anyone has insight.
I'm trying to get my Contour fan setup working. With this radiator I was going to have to trim the sides of the fan shroud to get them to fit flush. If it's not one thing, it's another. Sometimes I wonder why I bother...
Edit 2 hours later.
I'm currently trying to gently push the power steering lines a little lower to see if I can get some clearance. Another issue is the AC condenser needs to be moved forward, so I'm making some new brackets for that.
1982 Jeep Scrambler
43Duc is offline
post #29 of 35 Old 05-22-2020, 06:34 PM
258
43Duc,
If the radiator is out, solder a 1/8" thick brass plate where those lines hit under the radiator. I did this to mine just to help them from rubbing directly against the radiator when you hit a bump. It doesn't have to be large; 1 1/2" x 2 1/2"?
258 is offline
post #30 of 35 Old 05-22-2020, 07:43 PM
43Duc
43Duc's Avatar
1982 CJ8
Originally Posted by 258 View Post
43Duc,
Thanks for the tip. I had to make new brackets to mount the AC condenser and change how it was bolting to the grill and that bought me some room. I removed the hard line mounts for the power steering from the frame to get some flexibility. Those two things seem to have gotten me closer to where it needs to be. There is constant contact between the hard lines and the radiator, so I'll either do the patch you mentioned or wrap the lines in rubber when they make contact.
My first post about this was clearly made out of frustration as it turns out the radiator does fit. I had a feeling it would which is why I didn't call Ledfoot to complain. I like to exhaust all options before I do that and in this case it looks like it may have worked out.
Now that I have the radiator fitting (for the most part), I can work on trimming my fan shroud to make it fit. The gap between the radiator mounting flange it slightly smaller than the stock one, so I have to trim the shroud to get it to fit up against the fins. I'll work on that tomorrow.
Wish I could post photos.
1982 Jeep Scrambler
43Duc is offline
