85 CJ7 Radiator - JeepForum.com
 3Likes
post #1 of 35 Old 10-29-2019, 04:52 PM Thread Starter
Geek
85 CJ7 Radiator
I bought a Champion 3 row radiator for my 85 CJ. Stock 4.2L that has a clutch fan. The radiator was recommended here on the forum in a few places but there is no way it will fit (2 or the 3 row) with the clutch fan there. (I looked closer and those who liked this radiator had the V8 and not the 6) So I question if the clutch fan is "stock". The radiator that is on there is offset back into the grill by 1 7/8 inch and the Champion 3 row is only about a quarter of an inch while the 2 row would be about 3/4 of an inch based on the specs.
Anyone have any good suggestions for a radiator when using a clutch fan on the mighty 4.2?
SPOILER ALERT: Go to post #18 for the fix!!!
Thanks
Geek
Geek is offline
post #2 of 35 Old 10-30-2019, 03:38 AM
whollsee
1982 CJ7
Thanks
Geek
If you mean as an alternative to the champion?...OEM style in copper brass...
https://www.summitracing.com/parts/s...jeep/model/cj7
When ever I hear the word 'Jeep' I reach for my wallet.
whollsee is offline
post #3 of 35 Old 10-30-2019, 06:36 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Does your radiator have a fill cap centered or off to one side?
Do you have a serpentine belt or v belts.
I know there was a waterpump with matching pulley about 1/2" shorter in length for the 258.
There was also a thinner grill but that started in 84 at least and if your grill was not replaced then it should be the thin one.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #4 of 35 Old 10-30-2019, 07:44 AM Thread Starter
Geek
My radiator has the cap centered and the engine has V belts. I did replace the water pump when I rebuilt the engine this last year but it was exactly like the one that was on there (only it worked better). As for the grill, I don't know. Believe I am the third owner so anything is possible I guess as far as the grill having been replaced. I'll have to see if I can find some info on the grill thickness and see if that's the issue.
Thanks for the info John.
G
Geek is offline
post #5 of 35 Old 10-30-2019, 08:11 AM
CrustySprings
Geek,
I have an '85 CJ 7 and two years ago I ordered a Champion radiator same as you did.
I also found that the new three core Champion would not fit with the existing fan and fan clutch. Next year I plan on trying again with a slim (less than three inches thick) electric fan and controller.
Champion's web page really should be updated.
258 cu. inch six, Team Rush ignition upgrade, T5, Dana 300, Superwinch lockouts, Black Diamond 3" suspension lift, greasable shackles, poly bushings, JKS quick discos, 32x11.50x15 Cooper STT's, American Racing 23 15x8 alloys, Uniden Pro 520XL CB radio, 2' adjustable tip Firestick antenna, Viair 460 onboard air system
CrustySprings is offline
post #6 of 35 Old 10-30-2019, 11:32 AM
scottyDive
Installed this one in myb84 with the I6 and a fan clutch
Sent from my SM-G960U using Tapatalk
Scott
86 CJ7 Laredo
84 CJ7 Renegade
70 Jeepster
scottyDive is offline
post #7 of 35 Old 10-30-2019, 01:19 PM
whollsee
1982 CJ7
Yeah I installed the spectra a few years ago but I don’t think they do a copper brass version now. Not in offset cap anyway.
whollsee is offline
post #8 of 35 Old 10-30-2019, 03:41 PM
jurgen24
85 CJ7 Radiator
I used the 2 core Champion version and it fits (just) for 258 I6 with clutch fan (serpentine belts). I did have to lower it a bit, otherwise the cap hit the underside of hood and would not close.
Sent from my iPhone using Tapatalk
jurgen24 is offline
post #9 of 35 Old 10-30-2019, 04:31 PM Thread Starter
Geek
Thanks all. Appreciate the inputs.
I looked at the 2 row Champion but if I read the specs correctly it's only a half inch narrower than the three row and that still won't get me clear of the clutch. Must be a difference in the serpentine and v belt configurations.
Again really appreciate the inputs.
G
Geek is offline
post #10 of 35 Old 10-30-2019, 04:38 PM
whollsee
1982 CJ7
G
Do you have fan shroud?
whollsee is offline
post #11 of 35 Old 10-30-2019, 05:38 PM
oldschool74cj5
hello
did you check summit racing. i know they have a copper one that is made in the USA. price was pretty good.
oldschool
oldschool74cj5 is offline
post #12 of 35 Old 10-30-2019, 11:11 PM
ddawg16
ddawg16's Avatar
G
V-belts? My 84 is the serpentine belt. With the stock fan, there must have been at least 5" of space between the fan and radiator. And it was the I6.
I now have a V8.....even less room.........but I also have electric fans.
ddawg16 is offline
post #13 of 35 Old 10-30-2019, 11:17 PM
258
The offset cap (toward driver side) was on the heavy duty cooling option. The Heavy Duty 2 core has more cross fins in the two rows and is the one to use if you have a fan clutch.
The standard 3 core is the one with a fixed 4-blade fan and spacer. Both BRASS! . . . Not my photo, but illustrates the difference.
258 is offline
post #14 of 35 Old 10-31-2019, 07:50 AM Thread Starter
Geek
Yeah I wish I had 5 inches of space. Here's a pic of the fan and in the background you can see it almost perfectly lines up with the flange on the grill where the radiator mounts. The other pic shows the space between the mounting flange and the radiator itself.
258 - Thanks for that pic. Will see if I can find a heavy duty like that one.
Geek is offline
post #15 of 35 Old 10-31-2019, 08:27 AM
DougE
1983 CJ7
Here's a thought for debate. Besides the fan clearance issue there have been issues with the hood prop interfering with the radiator cap. After a total disassembly, when I installed my shroud I found that it did not fit properly. After checking my disassembly photos, I found that the radiator should be inserted into the grille housing (from below) with the clip nuts installed on the radiator flange. This resulted in an assembly of: Shroud, Grille Housing Flange and then Radiator. All fit properly then. This arrangement could solve some of the interference problems folks are experiencing.
1983 CJ7, 258I6, T4, Dana 300, 31x10.5x15 DuraTrac
DougE is offline
