84 cj7 sway bar links bushings 2 piece or 1 - JeepForum.com
post #1 of 13 Old 09-06-2019, 06:23 PM Thread Starter
agear
I'm replacing my sway bar bushing. The sway bar is 15/16ths. I got moog rubber ones for the cross bar because they're rubber -less squeak and softer right. But the rubber moog ones I see for the end links uses 2 bushings in one eye instead of 1 hourglass bushing like the ones I'm taking out. So I dont know if I should use them. I read another thread that said they were the right ones and so were the poly ones that do come in the 1 piece design .
As long as metal is not rubbing metal in any condition we should be good but.....
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #2 of 13 Old 09-06-2019, 06:28 PM
X-Army
X-Army's Avatar
1979 CJ5
Replacing the hourglass-shaped bushings with 2-piece is standard practice.
X-Army is offline
post #3 of 13 Old 09-06-2019, 06:43 PM Thread Starter
agear
Interesting. Why is that ? And were all cj sway bar set ups essentially the same other than bar diameter ?
agear is offline
post #4 of 13 Old 09-06-2019, 08:48 PM
X-Army
X-Army's Avatar
1979 CJ5
My guess is that only a percentage purchasers of sway bar kits will have access to a suitable pressing device or the knowledge of how to do it without damaging the new bushing.
X-Army is offline
post #5 of 13 Old 09-07-2019, 05:23 PM Thread Starter
agear
Is it normal to have a gap in the split on the frame mounted new sway bar bushings ? I'm thinking it will soften up and will be able to be squeezed together .
agear is offline
post #6 of 13 Old 09-08-2019, 06:58 AM
Rsb201
Rsb201's Avatar
Are you sure you ordered the correct size?? Jeep used 2 different sized bars. I found that out when I replaced all my front end parts. I ordered the wrong size and had a gap like you referenced above. As far as the hourglass bushings, you could always just replace the entire dog bone link.
1986 CJ7 4.2 Weber T176 D300
Rsb201 is offline
post #7 of 13 Old 09-08-2019, 07:58 AM Thread Starter
agear
I thought I did but it looks like I bought the smaller size bushing. I think the 2 piece bushings fir the endlinks worked good.
agear is offline
post #8 of 13 Old 09-08-2019, 09:55 AM Thread Starter
agear
I had to order the prothane bushings to get the 15/16ths I needed.
Thank you . What kind of grease do you use for polyurethane to keep it from squeaking ?
agear is offline
post #9 of 13 Old 09-08-2019, 10:21 AM
Spieg8
1984 CJ8
Prothane sells grease too, that's what I use on all my greasable bushings.
It's not the Voltage, but the Amperage that will kill you.
Spieg8 is offline
post #10 of 13 Old 09-08-2019, 10:24 AM Thread Starter
agear
Perfect ! Thanx
agear is offline
post #11 of 13 Old 09-10-2019, 04:16 PM Thread Starter
agear
I went out there and checked to see if the 2 frame mount sway bar bushings had settled in some and they did. They're getting close to being closed up. I think with some lube and some more time on the bushings they will completely close . But that's gotta be a tight fit. Do you think it will be a problem with the sway bar moving like it does ? They might wear fast being so tight but I guess if they wear down the rubber enough it could end up a good fit. It depends how it wears. Does it rub away rubber or just soften it up ? I guess the issue is it will be wearing down fast while its settling in. Even though it's a tighter fit it may shorten the life of the bushings including the end link bushings. Not a big deal because I already ordered some that are the correct size . Are there any problems with using poly bushings fir the frame bracket and rubber fir the end links ?
agear is offline
post #12 of 13 Old 09-12-2019, 08:26 PM
X-Army
X-Army's Avatar
1979 CJ5
Same here. The Prothane kit I ordered from Amazon included all bushings, frame brackets, and a packet of their lube. My only gripe is that I had to widen the holes in the provided brackets, since my (factory) bolts were larger than their slots.
As for wearing down, I don't believe you'll see much of that with the poly bushings, especially if properly lubed. Having the gap in there is just an opening for dirt/sand to collect and act as an abrasive to break down your new bushings.
I can't imagine any issue with the link bushings being one material and the bar bushings being another, other than different longevity.
X-Army is offline
post #13 of 13 Old 09-13-2019, 02:08 PM Thread Starter
agear
Okay thank you. I may just sand down the rubber ones I have and save the poly ones for later
agear is offline
