79’ CJ5 Camber Adjust Recommendations - JeepForum.com
post #1 of 12 Old 07-29-2020, 01:09 PM Thread Starter
southtx
Junior Member
southtx's Avatar
1979 CJ5
Hoping for more help with my CJ5 build. I purchased the Lifetime Alignment at the local Firestone and below are pics of the initial and final results. The Firestone Rep said I was good to go like this and not to worry about it. The Left front Camber is in the green at 1.3 but the Right front Camber is in the red at 2.3. He did advise that I add caster shims up front but he couldn’t tell me what size or degree to purchase....???
What do you all think? Should I be good to go OR should I get the camber adjusting sleeves or outer shims and install those? I see I can get the adjusting sleeves on Summit and i may be able to get the shims at Oreillys. Any and all suggestions are appreciated. I will install these myself if they need to be added...
Thanks Again!
southtx is offline
post #2 of 12 Old 07-29-2020, 01:16 PM
Fourtrail
1974 CJ6
I would not worry about the camber #, but you do need to get a set of 5 degree caster shims put in between the perch and spring pack to get a good 5 or so degree positive caster number
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is online now
post #3 of 12 Old 07-29-2020, 02:18 PM
oldschool74cj5
hello
first thing are your ball joints good? then the first thing you need to get is the caster in. for the camber you can get the shims that go between the spindle and the knuckle. they work pretty well.
oldschool
oldschool74cj5 is online now
post #4 of 12 Old 07-29-2020, 04:10 PM Thread Starter
southtx
Junior Member
southtx's Avatar
1979 CJ5
Thank you FourTrail! I’ll pick up the 5 degree caster shims. Thats one of the #’s I needed to know.
southtx is offline
post #5 of 12 Old 07-29-2020, 04:16 PM Thread Starter
southtx
Junior Member
southtx's Avatar
1979 CJ5
Originally Posted by oldschool74cj5 View Post
hello
oldschool
oldschool74cj5, thank you for your reply as well! I have brand new moog balljoints- everything on the jeep is new or rebuilt. That doesn’t mean I installed anything correctly but I think I got it all right. I may have fouled up the camber sleeves that came with the new ball joints? Could installing them too deep or not deep enough cause my camber issue? I’ll start with the 5 degree caster shims, as recommended by fourtrail and then go from there. I do have a 2.5” BDS lift with M.O.R.E. Shackles (I think the shackles are stock length but i can’t remember for sure). Stock height body mounts...
southtx is offline
post #6 of 12 Old 07-29-2020, 05:48 PM
80cj
80cj's Avatar
1980 CJ5
From the time I got my Jeep brand new, it would wear the front right tire badly on the outer edge. I would rotate my tires every 3000 miles or so but it wasn't enough to correct the wear pattern. Found out that the right had slightly more than .75 degrees (I forget the exact figure) camber than the left side. I decambered the right side .75 degree with an adjustable ball joint. Tire wear is very acceptable now.
80cj is offline
post #7 of 12 Old 07-31-2020, 10:59 AM Thread Starter
southtx
Junior Member
southtx's Avatar
1979 CJ5
Thanks 80cj, I saw a few posts on other threads where you mentioned doing that but I can’t seem to find the adjustable joints.. I searched a bit yesterday for the spicers but haven’t had any luck finding them yet. Still looking and trying to decide which route to take...
southtx is offline
post #8 of 12 Old 07-31-2020, 11:07 AM Thread Starter
southtx
Junior Member
southtx's Avatar
1979 CJ5
Fourtrail, I’ve searched several sites and have found 4 and 6 degree shims but no 5’s. Which do u think would be better? I have the 2.5” lift, with the oem pitman arm if that makes a difference. I will likely get the steel type that way I can weld them on as some others have suggested on other threads to keep them from shifting. Removing and adjusting the steering knuckles is way out of my league and I don’t know of any shops near me that do that.
southtx is offline
post #9 of 12 Old 07-31-2020, 11:52 AM
Fourtrail
1974 CJ6
Originally Posted by southtx View Post
Fourtrail, Iíve searched several sites and have found 4 and 6 degree shims but no 5ís. Which do u think would be better? I have the 2.5Ē lift, with the oem pitman arm if that makes a difference. I will likely get the steel type that way I can weld them on as some others have suggested on other threads to keep them from shifting. Removing and adjusting the steering knuckles is way out of my league and I donít know of any shops near me that do that.
Go with the 6 degree shims. You should be between 5 and 7 degrees of caster and you were at .3 and .5.
post #10 of 12 Old 07-31-2020, 06:04 PM Thread Starter
southtx
Junior Member
southtx's Avatar
1979 CJ5
Awesome, thank you! I’ll get them ordered.
southtx is offline
post #11 of 12 Old 08-01-2020, 10:20 AM
80cj
80cj's Avatar
1980 CJ5
I got the Spicer adjustable ball joint from my NAPA dealer but that was a few years ago. I cant remember the brake caliper configuration for a 79 but if the caliper mounts with the spindle bolts, there are tapered shims that can be used. Shims can't be used on CJ's that mount the caliper on the steering knuckle because the rotor will not run perpendicular to the caliper.
80cj is offline
post #12 of 12 Old 08-02-2020, 01:23 AM Thread Starter
southtx
Junior Member
southtx's Avatar
1979 CJ5
Ok, thats good to know. I’ll go check with Napa on Monday.
southtx is offline
