78' CJ Restoration w/ 87' YJ tub - JeepForum.com
post #1 of 4 Old 03-29-2005, 09:47 AM Thread Starter
Vidman35
Guest
I am working on a ground up restoration/customization. I several questions. Any help you can provide will be greatly appreciated!
1. I've noticed that my old 78' steel doors do not have the same door latch as the new tub. Is it possible to change the handle and latch over to the type that will work on the 87' tub? Or am I going to need to buy new doors for it?
2. I've put a 4' skyjacker Lift kit on it... and I am thinking of running large wide tires and wheels. What do I need to do with the front end/rear end/transmission to best accommodate this.
3. What do you think of using HERCULINER on the underside, wheel wells and inside of the tub?
That's it for now!
Vidman35 is offline
post #2 of 4 Old 03-29-2005, 09:53 AM
teethdoc
1982 CJ7
I'll try to post pics of my CJ later. I did not do the restoration, but it is the exact same set up. '78 with 87 tub and frame. The doors are from the 87. Lined it with Herculiner. Take out the drain plugs and hose it right out. No one is the wiser. People always comment on how can a '78 look that new?
teethdoc is offline
post #3 of 4 Old 03-29-2005, 10:12 AM Thread Starter
Vidman35
Guest
Post away!
I cant wait to see the finished product!
Vidman35 is offline
post #4 of 4 Old 03-29-2005, 11:57 AM
jeepskate
I've seen people run the old-style doors on YJ's, so I know they'll work...have to remove the striker pins and may just have to fab up a 'catch' to fatten up the tub where it latches for a snug fit. My first swap job was an '87 onto a '79 and I used doors (full & half) from a 90's YJ.
Wow...didn't know Syjacker made lifts that tall I know...you meant 4" You'll need to regear your axles...ratio will be determined by tire diameter and how you use the Jeep.
You wouldn't be the first and won't be the last...only issue might be heat from the cat & muffler using it as an undercoating.
jeepskate is offline
My 84 cj restoration Bisqwik Jeep CJ Forum 22 11-08-2011 08:13 AM
'54 CJ-3B Restoration Mayfair_Jeeper Jeep CJ Forum 9 02-24-2008 02:33 PM
CJ5 Restoration CJ Runner Jeep CJ Forum 7 10-15-2007 08:32 AM
Restoration of a CJ-5 Roy Jeep CJ Forum 4 08-01-2007 02:34 PM
79 cj5 restoration Shane1680 Jeep CJ Forum 8 03-01-2007 05:33 AM
