77 CJ5 258 Emissions/Vacuum Help - JeepForum.com
 3Likes
post #1 of 47 Old 03-23-2020, 10:20 AM Thread Starter
beezler11
I recently removed the manifold assembly to fix a leak on my 77 CJ5 with the 258 I6. I forgot to take pictures of where all the hoses were hooked up when I removed them and can’t seem to figure out where they need to go. I do know that no air pump is on the Jeep, but honestly don’t know what else the previous owner removed or done. Just looking for the bare minimum to get it up and running again. Thanks! Will post pics as soon as I can.
beezler11 is offline
post #2 of 47 Old 03-23-2020, 10:24 AM Thread Starter
beezler11
Here’s a couple to start. I’ll take more when I get a chance.
A31F50E5-B605-4CC0-808A-AB053E499FB4_1584980642866.jpg   0FD6E8EE-91DC-4EED-A076-4391CCCDE4E2_1584980668366.jpg
post #3 of 47 Old 03-23-2020, 11:28 AM
Wabatuckian
Wabatuckian's Avatar
I've not had a CJ for 20 years, but I found my old manual languishing in my parents' garage some months back.
I doubt you have the feedback system and probably no air injection, but I'm including them anyway.
Josh
Wabatuckian is offline
post #4 of 47 Old 03-23-2020, 11:30 AM
Wabatuckian
... more.
uptillnow likes this.
post #5 of 47 Old 03-23-2020, 03:33 PM Thread Starter
beezler11
Some more pics...I’m new to this stuff so the manuals are a little confusing. I believe I have the line to the distributor correct. But I have the 2 red flexible hoses and one short black hose to figure out where they go.
9FDC7B1B-F40B-4DB9-8124-223E3839C50F_1584999002134.jpg   AEF8C86D-6CF6-4F7A-BE7F-9197E29C8587_1584999039140.jpg   BE363473-B24E-4CEB-99EC-C59810ECBDF5_1584999076270.jpg   image_1584999204489.jpg
post #6 of 47 Old 03-23-2020, 05:21 PM
Wabatuckian
1. Find the big tube off your charcoal canister and take it to the big outlet on the carb bowl.
2. Take ported vacuum to both the charcoal canister and to the distributor.
Do those three first. I'll come back by when I have time to sit down again.
Josh
post #7 of 47 Old 03-24-2020, 10:22 AM Thread Starter
beezler11
Josh
This sounds stupid maybe but I’m not sure that I have a charcoal canister..
post #8 of 47 Old 03-24-2020, 10:49 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Originally Posted by beezler11 View Post
This sounds stupid maybe but Iím not sure that I have a charcoal canister..
A.K.A. Fuel Vapor Storage Canister?
Wabatuckian likes this.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #9 of 47 Old 03-24-2020, 01:50 PM
Wabatuckian
It's a black canister, generally tucked in on the fenders.
Folks did tend to take 'em out.
Do you have anything like that?
Josh
post #10 of 47 Old 03-26-2020, 06:03 PM Thread Starter
beezler11
Don’t believe I have the charcoal canister.
post #11 of 47 Old 03-26-2020, 09:04 PM
Hurricane4
Hurricane4's Avatar
1979 CJ5
You can get a charcoal canister here:
https://store.delorean.com/p-6675-carbon-canister.aspx
As well as a roll-over check valve:
https://store.delorean.com/p-6703-ro...eck-valve.aspx
The charcoal canister on my '79 CJ5 is located directly under the windshield washer tank / reservoir.
"The unbelievable we can do immediately . . . the impossible just takes a little longer."
My College Accounting Professor
"Success is not final. Failure is not fatal. It is the courage to continue that counts"
Winston Churchill
Jeeps I Have Owned in Year Order:
'61 CJ5, '63 CJ6, '78 CJ5, '79 CJ5 (Current), '79 CJ7 & '86 CJ7.
Hurricane4 is offline
post #12 of 47 Old 03-27-2020, 06:13 AM
Wabatuckian
If you don't have one any longer, and if emissions aren't a concern, just plug those two hoses off. You don't want to be leaking ported vacuum, or be venting gas fumes into the engine compartment.
Josh
post #13 of 47 Old 03-27-2020, 03:15 PM Thread Starter
beezler11
http://store.delorean.com/p-6675-carbon-canister.aspx
http://store.delorean.com/p-6703-rol...eck-valve.aspx
Josh
I’ll find where those ones route and cap them off somehow. Maybe that’s why it’s had a pretty strong gas smell. Bottom line is that I’m trying to figure out what absolutely needs connected with my current setup which so far I’ve determined is no air pump and no charcoal canister.
post #14 of 47 Old 03-28-2020, 08:21 AM
Wabatuckian
Iíll find where those ones route and cap them off somehow.
Vacuum caps:
Click for the Autozone page.
Maybe thatís why itís had a pretty strong gas smell.
Very likely a contributor.
Bottom line is that Iím trying to figure out what absolutely needs connected with my current setup which so far Iíve determined is no air pump and no charcoal canister.
That's fine. The trick is to do it with no vacuum leaks. The timed spark advance is essential, and likely has another hose spliced off it going to something else.
Also, keep the EGR. It cools the valves and lowers combustion temp.
You're not in Northern Indiana, are ya'?
Josh
post #15 of 47 Old 03-28-2020, 01:22 PM Thread Starter
beezler11
Vacuum caps:
Josh
Nope, North Carolina here. The hardest part is not knowing what I do and don’t need or have. I don’t believe I have an EGR from looking at pics of what an EGR looks like. Maybe it used to go here...
