77 CJ Gearing - JeepForum.com
 1Likes
  • 1 Post By CSP
post #1 of 8 Old 09-27-2020, 05:13 PM Thread Starter
NCop143
77 CJ Gearing
Just picked up a 77 CJ with a 304 4 speed manual in it. It’s got 37’s and a twin stick transfer case. Haven’t gotten a chance yet to see what gears are in it but I’m planning to use it as a weekend cruiser, little to no off road use. What gear ratio would be optimal?
NCop143 is offline
post #2 of 8 Old 09-27-2020, 08:36 PM
turbogus
1978 CJ5
Let's see some photos
The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep
We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch)
Record heat waves and floods only occur when we visit that area
turbogus is offline
post #3 of 8 Old 09-28-2020, 08:08 AM
ADDZ71
1979 CJ7
Before anyone could answer the first thing to help would be what size tires do you currently have and what size do you plan to use. Does it drive good as is? I don't think changing the axle ratios would be first on my list of improvements. Most likely the gear ratio is 3.54 as I believe that was the stock choice that year. I run 33" tires and have 3.54 gears in my 1979 with a 304. I like the drivability as is. I have a 4 speed T-18 that I drive normally as a 3 speed (start in 2nd gear) and it runs about 2300 rpm at highway speeds (55-65mph) if I push it to 65 mph it goes above 2500 rpm.
ADDZ71 is offline
post #4 of 8 Old 09-28-2020, 11:21 AM
Fourtrail
1974 CJ6
Going to agree 3.54's and a v-8 seem to work well with 33" tires Have that setup in my 80 '5 and it has good pickup without running too high of an rpm at highway speeds
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #5 of 8 Old 09-28-2020, 12:08 PM
CSP
With 37s I would determine what gears it has and if the two are compatible before trying to determine what's optimal.
I have 5.13s and really like them, but my use is 98% off road only.
CSP is offline
post #6 of 8 Old 09-28-2020, 12:18 PM
4Low2G0
4Low2G0's Avatar
With 37's and mostly a weekend cruiser, I would go with 4.56 or 4.88.
Whats over that next ridge?
4Low2G0 is offline
post #7 of 8 Old 09-28-2020, 12:55 PM
ADDZ71
1979 CJ7
The font was covering the 37's in the original post. I agree you are going to want 4.56 or 4.88 to turn those.
ADDZ71 is offline
post #8 of 8 Old 09-28-2020, 08:28 PM
CSP
www.grimmjeeper.com/gears.html instead of guessing
bob4703 likes this.
CSP is offline
