6 smaller wires what size main wire - JeepForum.com
 2Likes
  • 2 Post By Fourtrail
post #1 of 14 Old 09-14-2021, 09:58 AM Thread Starter
agear
Got 6 wires i have grounded on the same spot. I'm moving them to a grounding block. What gauge should the main ground feed be if you will ?
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is online now
post #2 of 14 Old 09-14-2021, 10:27 AM
mpulokas
1977 CJ7
Do you mean the main one from the battery to the grounding block?
- MAP
mpulokas is offline
post #3 of 14 Old 09-14-2021, 12:57 PM Thread Starter
agear
Naw i mean as a chassis ground
agear is online now
post #4 of 14 Old 09-14-2021, 01:08 PM
Fourtrail
1974 CJ6
Table showing wire size and length for amperage. If your 6 wires are 14 gauge/rated for 30 amp at 7' running distance, then 6*30=180 amp possible, so a #8 wire from the ground block to the battery negative terminal.
John Strenk and robblue6412 like this.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is online now
post #5 of 14 Old 09-14-2021, 03:27 PM Thread Starter
agear
6 smaller wires what size wire
Ok ty. The store only had 4 gaige cable so I went with that for now . I dont like the way it looks at the moment. . Would probably look better with some double crimp star ring terminal. That would look more authentic
agear is online now
post #6 of 14 Old 09-14-2021, 04:14 PM
CSP
So is that 4ga cable not from the battery to the grounding block? It sure looks like it's going up to the battery post.
CSP is offline
post #7 of 14 Old 09-15-2021, 12:56 AM Thread Starter
agear
Hey csp. No its not actually. It's going to the battery tray bolt. They were all chassis grounds anyway so I figured why go to the battery.
agear is online now
post #8 of 14 Old 09-15-2021, 04:11 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Because it will eliminate any problems from rust getting between the battery and the chassis ground.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #9 of 14 Old 09-15-2021, 07:49 AM
mpulokas
1977 CJ7
Yes, run the grounding block direct to the battery post. Get some of those "military" style post clamps so you can run multiple wires direct off the battery (starter motor for one). Then go to NAPA and have them make you some nice custom (length, size, terminal) ground wires for all your needs.
- MAP
mpulokas is offline
post #10 of 14 Old 09-15-2021, 09:59 AM Thread Starter
agear
Ok will do. Another problem im having is the ring terminals tend to turn and twist when I tighten down the battery terminal nut
agear is online now
post #11 of 14 Old 09-15-2021, 08:48 PM
mpulokas
1977 CJ7
get these and you will be much happier. You might need new cables but it is worth it.
(note: I don't endorse this one just grabbed a fast example)
https://www.amazon.com/Ampper-Milita...s%2C209&sr=8-4
- MAP
mpulokas is offline
post #12 of 14 Old 09-20-2021, 04:04 PM Thread Starter
agear
http://www.amazon.com/Ampper-Militar...s%2C209&sr=8-4
Won't the ring terminals I connect to the battery terminals still get bent and twisted when you tighten down the clamp nut .
agear is online now
post #13 of 14 Old 09-20-2021, 06:46 PM
pedal2themetai
1956 CJ5
HI Just my opinion but those ring clamps are worthless.. use the one's mpulokas posted.
good luck
tim
pedal2themetai is offline
post #14 of 14 Old 09-23-2021, 04:10 PM
CSP
It has been my experience after ordering three sets of the "military" grade terminals from Amazon that all they have is pure crap.
They may have the look, but they are not made of the correct grade of lead. They're hard as a rock and do not tighten correctly on the battery terminals. If they're shiny or say zinc plated just forget about them.
These are legit, not some cheap Chinese made knock off. https://www.bigmikesmotorpool.com/co...-and-terminals
CSP is offline
