JeepForum.com (https://www.jeepforum.com/forum/)
-   Jeep CJ Forum (https://www.jeepforum.com/forum/f8/)
-   -   4 bbl carb on wrong? (https://www.jeepforum.com/forum/f8/4-bbl-carb-wrong-4434927/)
gutthans 06-10-2021 09:37 AM
Originally Posted by mudbfun (Post 41289941)
That is incorrect. If both primarys are on the same plane then they will both only be feeding half of the engine!
John has already addressed this, but you should go back and look closer at the two manifold designs you are trying to compare. Your comment applies to the V-8 design where cylinders are opposed and that runner orientation is not at all what happens on a straight six!
pedal2themetai 06-10-2021 09:59 AM
Hi, I'm with Kevin CJ7.. It looks like a Spread bore carb and a square bore intake.. that's the first thing I saw.. Everyone keeps talking about orientation .. No matter how you orientate it its not going to work with that intake or adapter. You need a spread bore to square bore adapter to make it work.
Spread bore means that the secondary are bigger than the primary and Square bore all 4 openings are the same size
good luck
tim
Fourtrail 06-10-2021 10:11 AM
1 Attachment(s)
Not sure what people are seeing, but the carb is a square bore edelbrock performer/carter AFB. Definitely not a spread bore carb.
85Tuxedocj7, can you get a picture/the numbers from this location on the carb? That will tell us the size and give a starting point to if the carb is too big or other suggestions.
John Strenk 06-10-2021 10:24 AM
1 Attachment(s)
It's hard to tell because of perspective aberration but if the gasket opening is trasoidial shaped then maybe it is a square bore but it appears the secondaries are a bit wider than the primaries comparing how close the secondaries comes to the edge of the remains of the gasket.
Attachment 3992083
There always is a chance of the secondaries are just wide enough to fit in the spacer openings and the primaries are smaller then the spacers opening so all the valves could work.
mudbfun 06-10-2021 10:25 AM
Originally Posted by jeepdaddy2000 (Post 41289957)
I stand corrected and owe gutthans an apology.
My depth of knowledge of 4 and 6 barrel intakes is showing:oops:.
Ditto. I defer to Johns expertise.
Re; the spread bore. It may be possible to overcome a carb to manifold mismatch via a different spacer. ??
Fourtrail 06-10-2021 10:32 AM
https://www.jeepforum.com/forum/atta...adbore-not.jpg
Bad camera angle, that is an edelbrock square bore base plate. Plus any spread bore has an exaggerated difference between the primary and secondary butterflies.
https://www.jeepforum.com/forum/atta...wrong-carb.jpg
Edit: if it is a very early Carter AFB, there were a few that had slightly smaller primary butterflies, but they were still a square bore design and should work just fine with that manifold as the secondary butterflies are still smaller than the bore in the intake.
John Strenk 06-10-2021 10:36 AM
That would be a mistake!! ;)
dont need one....
See fourtrail picture
John Strenk 06-10-2021 10:37 AM
Yeah, that looks like it.
Small difference in throttle plates size but center of throttle plates are 'square'
a spread bore has spacing of center of throttle plates way different. Not just size difference
mudbfun 06-10-2021 10:40 AM
Affirmative. My apologies. That design is VERY different then the ones I am familiar with. Especially the narrower runners for the primaries. It will be important to get that orientation right. Learning is good! Thank you! :thumbsup:
pedal2themetai 06-10-2021 10:45 AM
HI .. I still say the carb is a spread bore.. Look at the center divider of the carb.. One is smaller than the other.. I have a square bore Edelbrock and just looked at the bottom and both are the same size. In his picture of the actual carb one is smaller than the other (spread bore).. My square bore also has 4 bolt down holes..
He needs a spread bore to square bore adapter
good luck
tim
mudbfun 06-10-2021 10:50 AM
good luck
tim
All he needs to do is place the spacer on the carb upside down and try opening the butterfly's up. Ez issue to resolve.
Fourtrail 06-10-2021 10:51 AM
1 Attachment(s)
Which is correct for the 'square flange' Edelbrock 500 cfm carb. either way, it still should not need a spread bore adapter as the butterflies are still smaller than the intake bores. That carb is designed to bolt directly to a square bore intake.
https://www.edelbrock.com/performer-...-egr-1404.html
John Strenk 06-10-2021 10:55 AM
good luck
tim
I think the primaries are probably smaller than the opening in the manifold and the secondaries probably match the opening perfectly.
A spread bore adapter are much much bigger
https://static.summitracing.com/glob...2034_hb_xl.jpg
The throttle plates would not line up.
Fourtrail 06-10-2021 11:07 AM
Covered in my post just before yours, come on keep up John...:grin2:
mudbfun 06-10-2021 11:18 AM
Originally Posted by John Strenk (Post 41289947)
I think that depends upon the manifold design.
On some manifolds it helps with smoothing the airflow out the carb giving it a chance to mix properly.
If the base of the carb is mounted on a manifold that instantly changes direction to the left and next instant to the right, you going to get different mixtures in either direction.
Smooth air flow out is just as important as smooth air flow in for "drivability"
If you only run at WOT then that changes everything also as opposed to driving to the grocery store during the week.
Most of my engine performance know how is from working on Chevy small blocks. Clearly not everything is equal across the board, but some basic things will always apply.
I agree that in some cases they could be beneficial for better fuel atomization and distribution depending on the manifold, carb and so on. Either way I dont think the performance difference from a spacer is anything earth shattering though, and in most cases it is hardly noticeable. If it were just a case of getting the carb height correct for the purpose of attachments I wouldn't hesitate to use one.
The time now is 09:34 PM.
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
