4.0l Valve cover torque specs - JeepForum.com
post #1 of 6 Old 10-20-2021, 06:56 AM Thread Starter
MikeB82
1982 CJ7
I am in the process of doing the weaver 4.0l head swap and I dont have specs for torque on the valve cover with those special VC bolts/grommets anyone done this conversion cause I will need further help along the way. thanks Mike
MikeB82 is offline
post #2 of 6 Old 10-20-2021, 07:20 AM
Axhammer
Axhammer's Avatar
4.0L & 4.2L Engine Torque Specs
Description
Specification
Camshaft Sprocket Bolt
50 ft-lbs
Crankshaft Pulley To Vibration Dampener Bolts
20 ft-lbs
Cylinder Head Bolts 4.2L
85 ft-lbs
Cylinder Head Bolts 4.0L
First 22 Then 45 Then 45
Then 100 ft-lbs For Bolt 11
Then 110 ft-lbs For Remaining Bolts
Flywheel/Flexplate bolts
105 ft-lbs
Oil Pan Mounting Bolts 1/4 x 20
84 in-lbs
Oil Pan Mounting Bolts 5/16 x 18
132 in-lbs
Oil Pump Mounting Bolt Short
120 in-lbs
Oil Pump Mounting Bolt Long
17 ft-lbs
Rear Main Bearing Cap Bolts
80 ft-lbs
Rocker Arm Bolts
19 ft-lbs
Tensioner Bracket-To-Block Bolts
14 ft-lbs
Timing Chain Cover-To-Block Bolts
60 in-lbs
Timing Chain Cover-To-Block Studs
16 ft-lbs
Valve Cover Bolts With RTV
28 in-lbs
Valve Cover With Permanent Gasket
55 in-lbs
Vibration Damper Center Bolt (Lubricated)
- 80 ft-lbs
Why do I own a CJ? I like to “Balance the wrench and the steering wheel”
1985 CJ-7 Sebring Red, White hardtop, 284 CID inline six (4.7) TF 999 auto
2020 JLU Black, Black hardtop, EcoDiesel, 35’s on 2” Mopar lift
View my Pontiac in my profile
Axhammer is offline
post #3 of 6 Old 10-20-2021, 08:55 AM
bob4703
1974 CJ5
I wonder how many folks have torque wrenches that measure in inch pounds. I found one at a yard sale for $5 20 years ago. You can almost over torque 28 inch pounds with a nut driver.
Don't forget to check the torque after a few miles of driving. I always do it after I use a tank of gas.
Paved roads are prime examples of government over spending!
bob4703 is online now
post #4 of 6 Old 10-21-2021, 08:15 PM
DaveMueller
DaveMueller's Avatar
1976 CJ5
I have one with a calibration sticker. What do I win?
"You came here in that thing? You're braver than I thought."
DaveMueller is offline
post #5 of 6 Old 10-22-2021, 08:31 AM
bob4703
1974 CJ5
You just won a non over torqued valve valve cover bolt with the bolt head still intact. Could you post a picture of the calibration sticker?
post #6 of 6 Old 10-22-2021, 10:58 AM
DaveMueller
1976 CJ5
I never said it was current :-)
