304 timing - JeepForum.com
 1Likes
  • 1 Post By JEEPFELLER
post #1 of 6 Old 10-12-2021, 04:12 PM Thread Starter
kmiller7351
1981 CJ7
304 timing
Quick question but what is the timing supposed to be set at? Having a mech time it for me but need info on TDC ect. trying to fix brakes and air i suppose in sys.
kmiller7351 is offline
post #2 of 6 Old 10-12-2021, 05:41 PM
JEEPFELLER
JEEPFELLER's Avatar
1977 CJ5
By the book for a manual transmission----auto info if you need it!
'72-'79----5 before @ 750 RPM
'80---Exc CA 10 before---CA 5 before @ 700 RPM
'81---Exc High Altitude---8 before @ 600 RPM---High Altitude----12 before @ 700 RPM
Disconnect and plug off the vacuum advance hose to the distributor
Reconnect when task is done
Some folks experiment with their timing for performance or MPGs
----JEEPFELLER
kmiller7351 likes this.
JEEPFELLER is offline
post #3 of 6 Old 10-14-2021, 10:13 PM
howardellis
Just a quick inquiry, but what is the recommended timing? I'm having a difficult time, but I need information about TDC and other things. In sys, I'm guessing you're attempting to repair brakes and air.
howardellis is offline
post #4 of 6 Old 10-15-2021, 03:40 AM
BagusJeep
BagusJeep's Avatar
1981 CJ7
Spongy brakes?
What parts are on it? Have you ever seen the brakes working properly?
The physical conditions that I look at are:
- flexible brake hoses - in particular cracks and bulges
- fluid leaks - a pinhole in a brake line will make the brakes spongy but you will find fluid missing
- booster to master cylinder clearance. Supposed to be around 15 thou, a few millimeters and the brake pedal will floor
- Combination / proportioning valve - if this is stuck one way you will not get the brakes bled, depending on model you can check the setting and hold it there.
- brake calipers on front - make sure they are not swapped, the bleed nipple needs to be at the top of the piston, not the bottom. Have it on the bottom and you will not get the air out.
Then you need to bleed it. the master cylinder can be bled in a number of ways but as the pedal does not push the plunger all the way, it needs special attention. Best is to take it off and bench bleed it. Then follow the bleed procedure from the longest or furthest point back to the shortest.
BagusJeep lives in Bali with far too many 4x4s:
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
1980 Land Rover Series III 109" troop carrier - ROVER
BagusJeep is offline
post #5 of 6 Old 10-15-2021, 10:17 AM Thread Starter
kmiller7351
1981 CJ7
No leaks, still getting bubbles after 3 quarts rear per side as of today. There is an intermittent series of large bubbles at times. The brake pedal always did go to floor when i first got it. Will run later to see if there is a difference but all four have decent flow
post #6 of 6 Old 10-15-2021, 07:18 PM
JEEPFELLER
JEEPFELLER's Avatar
1977 CJ5
TDC? See post 5 in here https://www.jeepforum.com/forum/f8/number-1-a-4402475/
Brakes? See Post 21 in here https://www.jeepforum.com/forum/f8/b...43/index2.html
Positive feedback???
----JEEPFELLER
