304 Rebuild - JeepForum.com
 2Likes
  • 1 Post By bob4703
  • 1 Post By jeepdaddy2000
post #1 of 7 Old 11-01-2019, 01:17 PM Thread Starter
mcmurry
1974 CJ5
304 Rebuild
So the 304 in my 74 CJ5 is locked up. Who besides Summit Racing has complete engine rebuild kits?
Thanks.
mcmurry is offline
post #2 of 7 Old 11-01-2019, 02:52 PM
Ollie09
1977 CJ5
Jegs
Rock Auto https://www.rockauto.com/en/catalog/...1309452,engine
Probably most all the chain auto parts stores
Ollie09 is offline
post #3 of 7 Old 11-01-2019, 04:20 PM Thread Starter
mcmurry
1974 CJ5
Thanks. I tried Auto Zone, Advance, and O'Riellys but they only had gaskets.
mcmurry is offline
post #4 of 7 Old 11-01-2019, 08:16 PM
adman02
1979 CJ7
Too bad you're not closer to NC. I have a buddy that's about to take a partially disassembled 304 to the scrap yard.
adman02 is offline
post #5 of 7 Old 11-02-2019, 12:33 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
I just Googled "AMC 304 master engine kit" and came up with a whole page of offerings......
The duty of a patriot is to protect his country from it's government
Thomas Payne
jeepdaddy2000 is offline
post #6 of 7 Old 11-04-2019, 11:09 AM
bob4703
1974 CJ5
I'll bet you can find all the parts you need to rebuild it from any of the stores. If it is locked down you don't want a master kit. You will probably need over bore pistons and rings and under sized bearings. Your machine shop will give you a list of what to order.
pedal2themetai likes this.
Paved roads are prime examples of government over spending!
bob4703 is offline
post #7 of 7 Old 11-04-2019, 09:18 PM
jeepdaddy2000
1971 CJ5
Master kits come with piston size options, usually in .010, .030, .040, and .060 over. In the old days, some kits included a .010/.010 crank as well. There are still a couple of vendors that offer a crank as an added component. Depending on where you live, you may be able to find a machine shop locally that can turn your crank if it is needed. If not you will have to mic the crank and order the appropriate bearings (which should be offered with the kit as well).
As Bob stated, you will want to disassemble it and have your machinist give you an idea on what he recommends boring it out to.
bob4703 likes this.
Thomas Payne
