304 part identification - JeepForum.com
 4Likes
  • 4 Post By Ollie09
post #1 of 9 Old 10-17-2021, 04:09 PM Thread Starter
HildeCJ7
HildeCJ7's Avatar
Hi guys. Currently rebuilding the carb on my 304. Can you tell me the function of the items circled in the attached picture?
HildeCJ7 is offline
post #2 of 9 Old 10-17-2021, 04:19 PM
JeepinGeo
JeepinGeo's Avatar
Im probably totally wrong but I would say maybe a fuel vapor line or fuel return, but that doesnt make sense to me going into the intake. Line is a hard line and too small of diameter for coolant I would guess?
JeepinGeo is offline
post #3 of 9 Old 10-17-2021, 05:54 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
If it's the part I think it is, it's called an EGR Dump Valve. It prevented the EGR from operating at low vacuum pressure.
When I built my 360, I searched for days to find one, anywhere. Never found one. I even started a thread, here, and nobody knew what is was, or where to fined one.
It's one of the reasons I omitted the EGR, and capped off the opening at the intake.
Matt
Matt1981CJ7 is offline
post #4 of 9 Old 10-17-2021, 08:29 PM
Ollie09
1977 CJ5
Heat tube for the automatic choke coil.
Ollie09 is offline
post #5 of 9 Old 10-18-2021, 07:15 AM
Matt1981CJ7
1981 CJ7
Ollie09 is spot on correct. I forgot all about the heat tube.
Sorry for my misinformation.
Matt
post #6 of 9 Old 10-18-2021, 09:28 AM
pg_jglr
1981 CJ5
Do i need one of these? Looks like mine might have gotten removed at some point in its life.
Sent from my SAMSUNG-SM-G935A using Tapatalk
pg_jglr is offline
post #7 of 9 Old 10-18-2021, 09:41 AM
Matt1981CJ7
1981 CJ7
You only need it if your carb has a hot air operated choke. If it has an e-choke, or is a manual choke, the air tube is not needed.
Matt
post #8 of 9 Old 10-18-2021, 02:51 PM
pg_jglr
1981 CJ5
Good to know. The 80s era motorcraft 2150 carb that i installed looks like it has a port for it but runs fine.
pg_jglr is offline
post #9 of 9 Old 10-18-2021, 08:23 PM Thread Starter
HildeCJ7
HildeCJ7's Avatar
Thanks guys. I have the original motorcraft carb. I think it’s a 2150, but doesn’t seem to be super clear between the 2100-2150. It’s a ‘78 golden eagle. I thought the carb was electric, as it definitely has a electrical connection, but makes sense that it’s got the heat tubes for the choke coil on it.
HildeCJ7 is offline
