304 exhaust manifold options - JeepForum.com
post #1 of 4 Old 10-15-2021, 12:53 PM Thread Starter
MattC71
1975 CJ5
When I got my 75 CJ5 it came with fenderwell headers. As much as I like the sound of a V8 with headers, they are not good for trail use. I'm sure I will bounce a log or rock off of the header, collector or muffler at some point. I have 2 options, either block hugger style headers or stock cast iron. Is there such a thing as hi flow stock manifolds? Anyone in the NW have some?
Thanks
MattC71 is offline
post #2 of 4 Old 10-15-2021, 01:23 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I used stock cast iron exhaust manifolds on my 360. I've read they flow pretty well.
My exhaust guy also had a creative way to get the crossover tucked above the frame, instead of crossing below it like the stock configuration.
Matt
Matt1981CJ7 is offline
post #3 of 4 Old 10-15-2021, 07:23 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
I agree with Matt. For anything under 3500RPM's, stock manifolds will flow as well (if not better) than headers. You also eliminate all the heat, leaks, rust, and noise of headers. You still can run duals if you feel the need or up the diameter of the single pipe to increase flow.
Paperwork will ruin any military force.
Chesty Puller
jeepdaddy2000 is offline
post #4 of 4 Old 10-15-2021, 11:51 PM
Hurricane4
Hurricane4's Avatar
1979 CJ5
Check out Waldron's for complete OEM type exhaust system from Y-Pipe back to tailpipe:
https://waldronexhaust.com/product/1...w-o-converter/
For exhaust headers that exit in the stock locations (shorty headers) see here:
https://www.summitracing.com/parts/p.../cj5/year/1979
"The unbelievable we can do immediately . . . the impossible just takes a little longer."
My College Accounting Professor
"Success is not final. Failure is not fatal. It is the courage to continue that counts"
Winston Churchill
Jeeps I Have Owned in Year Order:
'61 CJ5, '63 CJ6, '78 CJ5, '79 CJ5 (Current), '79 CJ7 & '86 CJ7.
Hurricane4 is offline
