A 304 engine build video power nation - JeepForum.com
 9Likes
  • 5 Post By agear
  • 1 Post By weapon
  • 1 Post By Shawn Watson
  • 1 Post By cjoffroad
  • 1 Post By Mister4x4
post #1 of 12 Old 02-21-2021, 02:46 PM Thread Starter
agear
https://youtu.be/O-xeB-m9wB8
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is online now
post #2 of 12 Old 02-21-2021, 03:25 PM
Shawn Watson
Shawn Watson's Avatar
1983 CJ7
Right on. You guys are turning me into a Power Nation junkie
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
Shawn Watson is offline
post #3 of 12 Old 02-22-2021, 04:58 PM
GP_Pete
GP_Pete's Avatar
1930
I saw that one. They got 330 hp out of that 304. Only thing is they used the edelbrock proflow 4 port injection manifold. Annnnd the eddy aluminum heads. Thats $2k for the proflow and $2k for the heads! My 360 is getting done next winter - but im going to use sock heads with some porting and polishing. Probably reuse my performer intake and go with the matching cam. Those heads are nice but really do their work in rpm ranges i rarely would see.
Sent from my iPhone using Tapatalk
AMC 360
GP_Pete is offline
post #4 of 12 Old 02-22-2021, 06:35 PM
oldschool74cj5
hello
that looks like a easier and better choice then trying to do a complicated LS swap to me. i know part of it is im not a bowtie guy.
oldschool
oldschool74cj5 is offline
post #5 of 12 Old 02-22-2021, 08:50 PM
weapon
1983 CJ7
8k in real world expense for a 304. That episode was nuts. If you are going to spend that much you need to be doing a 401.
bwwhaler likes this.
weapon is offline
post #6 of 12 Old 02-23-2021, 04:22 AM
Shawn Watson
1983 CJ7
One of these days when I have hundred-dollar bills falling out of my arse and nothing to do, I'd like to build a 304 just to see what's what. I certainly wouldn't put a 185cc runner on a sub-6,000 rpm 310ish cube engine nor would I run an intake valve that's 53% of the bore diameter and I certainly wouldn't use a single-plane, MPFI or not.
Not a knock on the guys who built it whatsoever; when your sponsors tell you to push their products and you have a guy in need of an engine, that's what you use. I do wish they'd have pumped the compression up to at least 10:1 with aluminum heads and that EFI, though.
Shawn
downs likes this.
post #7 of 12 Old 02-23-2021, 09:49 AM
Axhammer
Axhammer's Avatar
They did an inline six 4.0/4.6 that came out of a 2 door XJ over a year ago. They promised to run in on the Dyno for a comparison but I can’t find that episode. Has anyone seen the 2 door XJ with a 4.6 inline six dyno episode?
Why do I own a CJ? I like to “Balance the wrench and the steering wheel”
1985 CJ-7 Sebring Red, White hardtop, 284 CID inline six (4.7) TF 999 auto
2020 JLU Black, Black hardtop, EcoDiesel, 35’s on 2” Mopar lift
View my Pontiac in my profile
Axhammer is offline
post #8 of 12 Old 02-23-2021, 12:05 PM
cjoffroad
cjoffroad's Avatar
1980 CJ7
At about the 15 minute mark are the dyno results. 133 Hp and 197 lb ft
cjoffroad is offline
post #9 of 12 Old 02-23-2021, 01:24 PM
Axhammer
Axhammer's Avatar
Thanks...I wonder how much the new upgrades will up it from 133/197?
I guess those numbers aren’t bad considering it’s a chassis dyno and the Jeep is on 33’s. Its more than a 258 would make, but then it should more than double what a 258 would make.
Axhammer is offline
post #10 of 12 Old 02-23-2021, 02:23 PM
cjoffroad
cjoffroad's Avatar
1980 CJ7
Yeah that xj setup has to be a lotta drag on any engine. Considering they only made about 60 hp and 96 lb ft on the old 4.0L its a good improvement.
Axhammer likes this.
post #11 of 12 Old 02-23-2021, 05:27 PM
Mister4x4
Mister4x4's Avatar
1980 CJ7
I'm planning on the Pro Flow MPI on my 304, but I'll run stock heads with mild port & polish. I'm also thinking bumping up to 9.5:1 compression and 1.72 roller rockers with a similar cam should have me in the neighborhood of those numbers the Power Nation guys got. I ran a very similar recipe on my Mach 1's 351C and it's pulling around 400hp at the crank - with an Edelbrock 1406 carb (can't wait to see with the E-Street EFI does for it).
Eric
Mister4x4 is offline
post #12 of 12 Old 02-24-2021, 01:06 PM
downs
downs's Avatar
1995 XJ Cherokee
Shawn
One of my favorite shows. Them, Dirt Every Day, and Roadkill are what keeps me coming back for renewing my Motortrend on demand subscription.
1995 Jeep Cherokee Country 4X4 Stock
AW4/NP231/C8.25/D30/"UpCounty" suspension
downs is offline
