3 Point seat belt mounting - JeepForum.com
post #1 of 7 Old 05-03-2020, 07:08 AM Thread Starter
breceski
1977 CJ5
Replacing my seatbelts. Anyone have a good picture of the mounting on the floor? My seatbelts are not installed correctly and want to make sure I get these in right. Thanks for any help.
breceski is offline
post #2 of 7 Old 05-21-2020, 09:55 AM Thread Starter
breceski
1977 CJ5
Any one have any close up pics of how that are installed????
Thanks,
Bill
breceski is offline
post #3 of 7 Old 05-21-2020, 11:44 AM
adman02
1979 CJ7
I just bought and installed these in my 83 Scrambler. I chose them specifically because I would only need to use two holes for the retractable side (one hole on the roll bar and one hole on the floor). If you look closely at the bottom, you'll see a metal plate the connects the retractor end and the lap end (look at the pic and this will make more sense).
https://www.wescoperformance.com/92-...s-retract.html
adman02 is offline
post #4 of 7 Old 05-21-2020, 01:03 PM Thread Starter
breceski
1977 CJ5
I see that. I may have to order those because it looks like it would work for my cj. Thanks.
breceski is offline
post #5 of 7 Old 05-21-2020, 06:14 PM
brianscoob
brianscoob's Avatar
1976 CJ7
I need to do the same thing except i have a 1976 and it only required two seat belts and I want to go to 3 point eventually which mean I have obliviously have to do a little fab work on my roll bar. I will be looking to put the same belts in as these. Do I just need to weld the upper in place or drill and bolt down? I will admit it's different driving around with only the lap belt on, and I'd hate to have to kiss that steering wheel. I do drive pretty conservative on the roads with top and doors off.
brianscoob is offline
post #6 of 7 Old 05-22-2020, 06:57 AM
adman02
1979 CJ7
You probably want to drill a hole rather than weld (in case you ever want or need to remove the seat belt). You will also want to weld a sleeve in the hole that you drill to keep the roll bar from collapsing in under tension. And use grade 8 hardware. That’s what I’d do anyway.
adman02 is offline
post #7 of 7 Old 05-22-2020, 06:42 PM
MrPeter63
1983 CJ7
To the OP. The way my '83 7 is, your year 5 might be different but. The retractable bolts to the side of the tub on the B pillar, up to the roll bar, and back down to the floor. The bracket on the loose end bolts to the floor basically under the retractable with the belt pointing towards the front of the jeep. Getting to dark to take a pic, but if ya really need one i can try in the AM.
MrPeter63 is offline
