2bbl carter carb, trying to set correctly - JeepForum.com
post #1 of 3 Old 09-28-2021, 01:30 PM Thread Starter
GA1984Cj7
Junior Member
I might take this to the mechanic, but want to try first. The carter carb was rebuilt. Started off idling high 2000. I got a digital timing light made some adjustments with the Idle screw and distributor. Got it down to the 600s. Now I either smell strong odor of gas or strong exhaust. Just seeing if there are any suggestions, before I take it to a mechanic.
GA1984Cj7 is offline
post #2 of 3 Old 09-28-2021, 02:18 PM
Fourtrail
1974 CJ6
Is your choke fully open is the first thing to check, next, about where are the idle mixture screws set? 2-1/2 turns out from seated is normally a good starting point. You want to adjust the screws for the fastest idle and then bring the idle rpm down with the curb idle speed screw
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #3 of 3 Old 09-28-2021, 03:07 PM
258
258's Avatar
Make sure you DO NOT tighten those screws too much, Just go easy until they seat.
258 is offline
