258 Weber wiring question - JeepForum.com
post #1 of 2 Old 08-09-2016, 10:18 AM Thread Starter
claybuster84
1981 CJ5
Ok Guys, I have been looking all over the web for information but cant seem to find what I'm looking for. I have swapped my Carter BBD for a Weber 38 and need to know what components I can remove in the stock wiring system? I specifically am looking at the Idle Speed Controller located on the right front fender. I am running a TeamRUSH'ed Motorcraft distributor and MSD Blaster 2 coil. All my emissions crap is removed and I have added OBA and Dual Batteries, electric fans, winch, etc... (just to give an idea what I have) and have ran everything thus far to dedicated gounds with waterproof connections.
What all can I remove under the hood?
claybuster84 is offline
post #2 of 2 Old 08-09-2016, 10:36 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Well if you removed the SOL-VAC and the Idle speed controller box then there is not that much more to remove, unless it's some wires in the harness.
It was a pretty simple control that kicked to idle speed up if the intake heater or AC was turned on. Depending were you live, I wouldn't recommend removing the Manifold heater just yet.
John Strenk is offline
cj , jeep , wiring
