258 Running Too Cold? 🤔 - JeepForum.com
post #1 of 13 Old 08-02-2021, 04:13 PM Thread Starter
JeepinGeo
JeepinGeo's Avatar
Now I have read other forums about this topic. Most of what I've seen says 195-210° is normal operating temperature for a 258.
1979 CJ5 258. The radiator is a new standard aluminum 3 row. The fan is a mechanical 7 blade. It has the original shroud. The water pump is new. I run 50/50 Prestone. The thermostat is 180° stainless steel. I live in Central Florida. It gets hot and humid in the summer, and cold and dry in the winter. Since installation of the new parts, the gauge reads ~180° constant from 0 mph up to max speed (~65 mph) on any given day, cold or hot out. At idle it "might" get up to 190°. Can't seem to get it any hotter than that, no matter if I'm lugging it down a long trail or on a highway cruise. Engine appears to run great. Just not sure why the temperature remains so low. Would yall say the engine run too cold?
JeepinGeo is offline
post #2 of 13 Old 08-02-2021, 04:33 PM
CrustySprings
Sounds about like my '85 CJ 7 with the 258. A 180 degree thermostat is fine.
258 cu. inch six, Team Rush ignition upgrade, T5, Dana 300, Superwinch lockouts, Black Diamond 3" suspension lift, greasable shackles, poly bushings, JKS quick discos, 32x11.50x15 Cooper STT's, American Racing 23 15x8 alloys, Uniden Pro 520XL CB radio, 2' adjustable tip Firestick antenna, Viair 460 onboard air system
CrustySprings is offline
post #3 of 13 Old 08-02-2021, 04:45 PM
Techlight
Sounds like it's running as you built it. Assuming everything else works (which it does from your post) it's not really going to get any hotter than the 180 cause as soon as it reaches the thermostat temp it's going to transfer the water out of the block. I've heard of people putting in 180 degree thermostats. If I remember correctly 195 degree is stock but I'm not sure how much difference there is really going to be performance wise. I suppose you might get slightly (negligible) better gas mileage out of the 195...but i'm not sure you'd notice the difference.
If it runs fine I'd leave it ... if it bothers you the next time you're in there change it out for a 195. I don't think it's worth tearing it all apart for just that.
,[_____],
_-o||||||||o-_
()_)ŻŻŻŻ )_) 1984 CJ7 Renegade, 4.2L-TBI, D30, AMC20, 4.5" OME lift
Techlight is offline
post #4 of 13 Old 08-02-2021, 04:50 PM
gutthans
gutthans's Avatar
Gauge may be off a little, but you are nowhere near too cold. If you can't get enough heat in January, then consider a 195*. If it drops into the 160 range, then maybe you have a fail-open type of stat and it would be prudent to replace it.
gutthans is offline
post #5 of 13 Old 08-02-2021, 05:45 PM Thread Starter
JeepinGeo
JeepinGeo's Avatar
I will leave it be in that case. Just wanted some insight. Thanks for the feedback guys.
post #6 of 13 Old 08-02-2021, 07:30 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
If you run a 258 AMC engine it was designed to run with a thermostat that started to open at 195F and was fully open at 218F.
You have proven that your engine is not at risk of overheating, left to itself with no thermostat it would rarely even approach 195F.
The engine is designed to operate at 195F, the tolerances are fixed for this amount of thermal expansion and the emissions are measured at this. When I had $10 and 30 minutes I would IMHO change to the correct thermostat.
BagusJeep lives in Bali with far too many 4x4s:
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
1980 Land Rover Series III 109" troop carrier - ROVER
BagusJeep is offline
post #7 of 13 Old 08-03-2021, 01:17 AM
mudbfun
1973 CJ5
The fact that you dont get any hotter then 180* just means that your 3 core radiator and 7 blade fan with shroud are plenty efficient for your configuration. Understand that is the same setup that is used for many heavy duty trucks with a V-8 for towing applications. You could put in a hotter T-stat or run it just the way it is. Personally I don't think the motor is going to care either way.
mudbfun is offline
post #8 of 13 Old 08-03-2021, 02:54 AM
Shawn Watson
Shawn Watson's Avatar
1983 CJ7
I think you're giving those engineers from the 70s and 80s a little too much credit. A 195* is safe regarding engine heat and warm enough to run the heater and that's about it.
If I were going to change anything here, it would be that 7-blade fan. I'd run a non-thermal clutch and a 5-blade but that's just splitting hairs. Hey, it's nice to have a CJ on here that's not over-heating for once
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
Shawn Watson is offline
post #9 of 13 Old 08-03-2021, 04:31 AM
jay-h
Shawn
Engines, back to the 40s and 50s were designed for specific temperature ranges--the tanks and planes of WWII did not ignore the effects of temperature. To some degree for clearances and to some degree for efficiency (hotter is usually a bit more efficient, as long as it doesn't get hot enough to do mechanical damage), and even for cooling--a hot radiator sheds more heat than a cold one.
The 4.2 and 4.0 should be running 195-210 typically, and running a 195 year round will NOT cause overheat problems. If an engine is overheating with 195, then there are other cooling system issues.
I have had a couple of failures with 'failsafe' thermostats. At some point the 'fail safe' activates and the thermostat sticks open (not terrible, but not what you want).
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #10 of 13 Old 08-03-2021, 06:18 AM
bob4703
1974 CJ5
I looked it up in the 74 TSM. It says 205* for a 258 and 232, and 195* for the 304. If the OP lived in a colder region I'd say change it.
Paved roads are prime examples of government over spending!
bob4703 is offline
post #11 of 13 Old 08-03-2021, 06:27 AM
jay-h
Maybe this will help
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
jay-h is offline
post #12 of 13 Old 08-03-2021, 06:31 AM
bob4703
1974 CJ5
What temperature does "cold boiling" occur?
bob4703 is offline
post #13 of 13 Old 08-03-2021, 10:25 AM
LumpyGrits
You want a 195* t'stat.
Your engine will thank you!
Gary
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
