258 oil dipstick tube - JeepForum.com
post #1 of 18 Old 01-04-2020, 11:09 AM Thread Starter
ttounsley
Found my oil dipstick tube has ‘popped out’ and is leaking oil. It is not broken but can’t quite figure out how to re-install it properly so no leaking and am unable to find any info about how to re-install. It is the original tube on my 1985 258. That crack in the seam does have me wondering if it is trash now and need to get a new tube and dipstick. Any input is appreciated.
Also, anyone out there know how to properly connect the PCVs to a Howell TBI? Wondering if mine are incorrect and it’s pushing too much pressure.
Thanks for any and all assistance.
ttounsley is offline
post #2 of 18 Old 01-04-2020, 11:41 AM
only in a jeep cj
I welded one back together once but is was challenging due to the thin metal. I’d look for another one
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is online now
post #3 of 18 Old 01-04-2020, 12:04 PM
WildCard07
WildCard07's Avatar
I had the same problem on mine and replaced mine with the short style tube. I put the tube in the freezer for a few hours and then tapped it in without a problem.
WildCard07 is offline
post #4 of 18 Old 01-04-2020, 12:48 PM Thread Starter
ttounsley
Wildcard, what type did you get and where did you get it?
post #5 of 18 Old 01-04-2020, 06:33 PM
oldschool74cj5
hello
if you are not looking for a original one. mopar still makes one that is made for the later yj's. i believe morris jeep have them. you will need to get the new dipstick that goes with it also.
oldschool
oldschool74cj5 is offline
post #6 of 18 Old 01-05-2020, 08:01 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
This is a homemade tool designed for installing the dipstick tube. It was made from a socket of equal diameter as the tube (5/16" or 3/8" maybe?). It allows you to tap the tube into place from a bit of an angle away from the tube.
Hope this helps.
Matt
Matt1981CJ7 is offline
post #7 of 18 Old 01-05-2020, 09:43 AM
jay-h
https://i0.wp.com/www.powerlineblog....pg?w=496&ssl=1
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #8 of 18 Old 01-05-2020, 09:43 AM
keith460
keith460's Avatar
The easiest way to get the tube back in is to freeze it overnight. Pull it out of the freezer and coat the upper inserted portion with Bearing & Shaft Retaining compound. Use an oak wood stick or a tool like Matt made and hammer it gently back into place.
PM me if you need a complete, long version, 258 engine oil tube with dipstick. I just may part with it but I have to find it first or I may have sold it already.
1984 CJ-7 Renegade
keith460 is offline
post #9 of 18 Old 01-05-2020, 09:44 AM
jay-h
I can't believe this happened to someone else!
Mine snapped off right by the block. Got this fitting from Home Depot, drilled out the bore slightly, trimmed the stalk to fix up the small amount of additional length. Works fine. (in the 2 weeks it was broken before I knew it, no oil dripped out, so tight sealing is not that critical.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
jay-h is offline
post #10 of 18 Old 01-05-2020, 09:52 AM
jay-h
I've tried several times and the picture does not post. Don't know why, never had this problem before.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
jay-h is offline
post #11 of 18 Old 01-05-2020, 09:55 AM
jay-h
Try this (reduced size)
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
jay-h is offline
post #12 of 18 Old 01-06-2020, 01:38 PM Thread Starter
ttounsley
jay-h,
That is an interesting alternative and might have to try that route if I a unable to locate anything else. Thanks!
post #13 of 18 Old 01-06-2020, 01:40 PM Thread Starter
ttounsley
I guess there is no money to be made making these replacement tubes or someone would be doing it. Crazy I can find them for them for the V8 but not the 258.
post #14 of 18 Old 01-06-2020, 05:11 PM
Matt1981CJ7
1981 CJ7
This one is made for a AMC Eagle 258, so it's much shorter, but it should fit. You'll have to cut the dipstick accordingly.
http://www.bjsoffroad.com/Oil-Dipsti...der_p_692.html
Matt
post #15 of 18 Old 01-07-2020, 09:34 AM
cJAY904
I have fought this fight. I found one from an AMC eagle (short) that fit and I cut my dip stick.
https://www.jeepforum.com/forum/f8/a...-tube-4143769/
cJAY904 is offline
