2100 Venturi Swap? - JeepForum.com
 3Likes
post #1 of 16 Old 03-18-2019, 08:19 AM Thread Starter
tigercreek
tigercreek's Avatar
2100 Venturi Swap?
One of the many things I did to my 84 CJ7 years ago was to swap to a 2100 carb with the 1.08 venturi.
Recently, though, I have grown tired of the frequent hot start issues associated with the electric choke. That being said, I'm considering moving to a true manual choke.
I have several old 2100/2150 carbs and one of them has the factory manual choke setup. The problem is that it has the wrong venturi size.
A thought occurred to me to just swap in a 1.08 venturi to this carb.
Would there be any problem to this - other than a mismatch stamp/venturi carb?
No matter where you go, there you are.
tigercreek is offline
post #2 of 16 Old 03-18-2019, 09:10 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
The venturi is not an interchangeable part. It is cast into the carb body.
If you're dead set on switching to a manual choke, you should do it on the 1.08 carb.
Matt
Matt1981CJ7 is offline
post #3 of 16 Old 03-18-2019, 09:21 AM
Fourtrail
1974 CJ6
Yes you can swap the venturi cluster from one carb to the other. Make sure that the throttle bores are the same size between the two bodies, but I believe that they are.
tigercreek likes this.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #4 of 16 Old 03-18-2019, 09:46 AM Thread Starter
tigercreek
tigercreek's Avatar
Thanks.
I don't know why it didn't occur to me sooner.
I know I can bolt on an aftermarket manual choke to the cover of the electric choke but have never been a fan of those.
Since I have the donor carb that can make it happen I said "why not?".
post #5 of 16 Old 03-18-2019, 10:00 AM
Matt1981CJ7
1981 CJ7
I stand corrected. Always thought the cluster was part of the carb body on a 2100.
OP, exactly what problems are you having with the e-choke?
Matt
post #6 of 16 Old 03-18-2019, 10:23 AM Thread Starter
tigercreek
tigercreek's Avatar
Inconsistent and I can't figure out why.
Have/had Ford trucks with these carbs for years that I successfully rebuilt for confidence and reliability. Something about the choke in this one is not reliable.
After it gets hot sometimes it fires up on the first turn of the key and other times you have to play gas pedal hopscotch.
With a manual choke I won't have to worry about solving the electric choke problem.
Matt
post #7 of 16 Old 03-18-2019, 10:25 AM
Matt1981CJ7
1981 CJ7
OP, you may want to read this thread before you start swapping venturi clusters. Especially post #4.
https://www.tapatalk.com/groups/edsc...cks-t2032.html
Matt
post #8 of 16 Old 03-18-2019, 10:35 AM Thread Starter
tigercreek
tigercreek's Avatar
Thanks.
Good food for thought.
Fortunately for me I already own the carb/parts I'd be swapping around so if it didn't work out I could easily swap back.
post #9 of 16 Old 03-18-2019, 11:01 AM
John Strenk
John Strenk's Avatar
1976 CJ5
That is not really the venturi but the booster venturi that is replaceable.
That can get 'complicated' if you just swap stuff around.
You would still have a 1.2 with a 1.08 booster assembly installed.
That can cause poor intermediate throttle performance. (anywhere between closed and full throttle. )
The booster venturi is designed so that you get good mixture at slower RPM where the air speed will be down. So they add a booster venturi to improve the suction coming out the main feed.
The poor YF has two boosters trying to make the carb supply enough air at full throttle but still let you pull into the garage without driving through the back wall.
I would fix the electric and set it up correctly but if you want to use a manual choke, there are some nice conversion kits available that you can add to your existing carb.
John Strenk is offline
post #10 of 16 Old 03-18-2019, 11:08 AM Thread Starter
tigercreek
tigercreek's Avatar
Thanks
post #11 of 16 Old 03-18-2019, 09:14 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
The only way the choke will effect the starting when hot is if it doesn't come all the way off.
Have you verified this?
There are a couple of other issues associated with hot start issues.
uptillnow likes this.
The duty of a patriot is to protect his country from it's government
Thomas Payne
jeepdaddy2000 is offline
post #12 of 16 Old 03-19-2019, 05:06 AM Thread Starter
tigercreek
tigercreek's Avatar
I went and dug out my "box o' carbs" and found that I have 3 2100s with a 1.08 venturi. Unfortunately all of them are set up with electric choke.
I do have a couple of 2100s with a 1.23 venturi that are set up with factory manual chokes -so - I've decided to leave my existing carb as is and rebuild one of the 2100s and swap the manual choke fitting to it.
I've never swapped choke parts like this before so I look forward to the learning experience.
post #13 of 16 Old 03-21-2019, 10:07 AM
CJ5_Fan
CJ5_Fan's Avatar
1980 CJ5
I'm sure you already verified this but just in case, have you ensured that you are not supplying 12 volts to the choke at all times but are instead on a 12 volt source that is only hot while running so it doesn't preheat your choke every time the ignition is turned on?
1980 CJ5 Renegade with 304 v8
CJ5_Fan is offline
post #14 of 16 Old 03-21-2019, 10:09 AM
John Strenk
1976 CJ5
That is why the OEM setup uses an oil pressure switch to activate the e-choke.
It doesn't start heating the choke up until the engine is running.
post #15 of 16 Old 03-21-2019, 11:06 AM Thread Starter
tigercreek
tigercreek's Avatar
Yep
06 Grand Cherokee 5.7 Hemi to 2017 5.7 Hemi Swap KLK812 WK Grand Cherokee & XK Commander Forum 18 05-03-2019 10:01 AM
The 5.2/5.9 swap guide for YJs SunDevilJeeper YJ Wrangler Technical Forum 153 12-29-2018 10:50 PM
06 TJ 42rle to ax15/nv3550 swap complete... with some kinks to work out ! Mike1080p TJ Wrangler Technical Forum 13 09-26-2018 05:38 PM
4.0 Head Swap 7/16 & 1/2 Head Bolt Alignment Bushing Question Group_er Jeep CJ Forum 10 02-04-2018 12:47 PM
