1986 Jeep CJ Idle Issue and gauge question - JeepForum.com
post #1 of 1 Old 06-12-2020, 05:33 PM Thread Starter
[email protected]
Hi all,
I purchased my first CJ back in February and had no issues. Recently, though, it started to idle rough and would cut out. It would happen when I was coming to a stop or in neutral about to turn without stopping. Taking a look at the plugs, they had a white haze and I guessed I had been running lean. I thought it was maybe carb related, so I have been fooling around with that for the past few weeks. I was going to clean the venturi tubes, but found out today that the screws holding the choke plate on were rounded out. Any advice on how to get those out? While I had the air cleaner off and was playing around, I did manage to get the engine running better by giving the mixture screws about a quarter of a turn counter clockwise. I worry, though, that I may be just band-aiding the problem. BTW, what are the difference between the two screws?
I think my Jeep has already had the nutter bypass since I do not see a bunch of vacuum lines running under the hood. The carb is a Holey rebuild with a sticker saying it took place in 2012. What does the group think?
I also have a battery gauge that does not work. I would think this would be easy to fix, but I am not sure where to check for proper wire hook ups.
Also, the speedo will move as the jeep gets speed, but kind of "floats" around and does not show the speed. Is this the gear in the transfer case?
Thanks everyone for your help.
