1986 CJ7 Dana 44 Wheel Bearings - JeepForum.com
post #1 of 7 Old 12-07-2010, 11:16 AM Thread Starter
Spidy86
I looked through many related threads and still confused. I have a Dana 44 rear that needs bearing and seals. I ordered a set and what I got does not appear to be the same.. I hope someone can assist with the correct bearing/seal numbers..
The bearing that was sent to me is a National A-10, 9912 collar and 481837 seal.. This bearing appears one piece with the race connected. What I pulled is a Timken with no number on it...The race still needs to be pulled out of the axle tube.
I realize the Dana 44 has been used in many applications before and after 86..Further, 86 being an odd year as AMC ran out of the 20... Are all years interchangeable? Does anyone have the Timken numbers for bearing/seals for 86? Some applications call for an inner seal...I don't seem to have one on the 86...
Im not one to post but really need the help. I did see a few threads but nothing specific about the 86 D44...
Thanks..
Spidy86 is offline
post #2 of 7 Old 12-08-2010, 04:03 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Here are the factory 86 CJ D44 part numbers, maybe you can cross reference them.
J324 0086 - SEAL
J323 0115 - BEARING
“We the people are the rightful masters of both Congress and the Courts,
not to overthrow the Constitution but to overthrow the men who would pervert the Constitution” Abraham Lincoln, 1859.
CJ7-Tim is offline
post #3 of 7 Old 12-08-2010, 10:30 AM Thread Starter
Spidy86
Thanks for the numbers.. I'll let you know how I make out crossing them.
Spidy86 is offline
post #4 of 7 Old 12-08-2010, 11:40 AM
mjfitz99
Autozone sells the Timken bearings around here. I will have to put some bearings and seals in my D44 in the coming months, so I am curious to see what you come up with. It might be worth trying them, if you have one in New York.
mjfitz99 is offline
post #5 of 7 Old 12-08-2010, 12:16 PM
83vert
1982 CJ7
Not to hi-jack but spidy im in your area, do you have any good off road spots?
I am in deep
https://www.jeepforum.com/forum/f8/how-did-happen-rebuild-1113470/
83vert is offline
post #6 of 7 Old 12-08-2010, 02:37 PM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
Bearing - Timken U399 or SKF BR10
Seal - CR18731
LT1CJ7 is offline
post #7 of 7 Old 12-08-2010, 04:47 PM Thread Starter
Spidy86
Excellent LT1 and all that helped. The Numbers LT1 gave look like the bearings I took out. I was able to get the bearings at Autozone..Although, I had to go to two different stores to get all.
Doing a frame up that should have gone to the Junkyard However, making good progress now. Frame stripped and painted/axles rebuilt and hung on a RE 2.5 standard lift.
Long way to go yet! Again thanks to all..Mike
Spidy86 is offline
1986 CJ7 Dana 44? SilverRubiSC Jeep CJ Forum 4 01-19-2009 11:11 PM
1986 CJ7 front wheel bearings Hillbillyd Jeep CJ Forum 1 02-17-2008 01:26 PM
1986 CJ-7 Dana 44 ckritcoad Jeep CJ Forum 6 10-22-2007 09:08 PM
DANA 44 30 SPLINE REAR (How can you tell if the seals and wheel bearings are bad?) Boulder4x4 Jeep CJ Forum 4 07-18-2004 12:59 PM
1986 Dana 44 atmosphere Jeep CJ Forum 1 03-08-2002 10:59 PM
