LinkBack | Thread Tools |
1983 jeep cj7
Ok guys I took my Jeep out for a drive and it ran great when I turned off off and went in the store and come back out it wouldn’t do anything when I turn the key on the dash lights come on and radio but will not turn over I replaced the starter solenoid and still nothing has good power going into the solenoid and also to alternator. I’m lost and I figure it’s something simple all fuses are good also help lol
Sponsored Links | |||
i am sure others will chime in, but do you have power when you turn the key to start ? if not it could be the "real" switch sitting on the steering column , it is engaged by a metal rod from the key cylinder . if it is moved a little from right position it will NOT send power to the RUN wire going to the relay.
my build thread :https://www.jeepforum.com/forum/f22/danish-cj7-rebuild-1373618/
Does the key turn all the way to the start position and return?
1983 CJ7, 258 engine, T-4 trans. Mostly stock with some useful upgrades.
Previous Thread
Next Thread
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Posting Rules | |
