1981 Kentucky CJ7 build - Page 7 - JeepForum.com
 30Likes
post #91 of 301 Old 11-03-2019, 02:26 PM
agear
Originally Posted by jchal3 View Post
The problem is I tested without it, and it led to me tearing the dash apart..... it gonna be happy if I put it back together and find out all I had to do was turn the key......what a ******* hahaha
Sent from my SM-N960U using Tapatalk
Is the turn signal switch in the steering column still installed ?
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #92 of 301 Old 11-03-2019, 02:54 PM Thread Starter
jchal3
1934 CJ7
Its brand new..I replaced it to start....I just didnt think to turn on the key to test it, and jumped right into chasing wires....I'll put it back together tomorrow. And turn the key, and it will probably be fine....just mad I didn't turn the key before tearing apart the dash..
jchal3 is offline
post #93 of 301 Old 11-03-2019, 06:36 PM
agear
okay , I was just gonna say you can test it while you have the dash panel off. Might be a good idea
agear is offline
post #94 of 301 Old 11-04-2019, 06:04 PM Thread Starter
jchal3
1934 CJ7
What's the best way to test it?
jchal3 is offline
post #95 of 301 Old 11-05-2019, 05:16 PM
agear
With your ignition switch hooked up and your turn signal switch installed just put the key in the position and work the switch just like you're using it driving
agear is offline
post #96 of 301 Old 11-06-2019, 08:44 AM Thread Starter
jchal3
1934 CJ7
Should I make the VROOM VROOM sound as I'm doing it?? Hahah just messing around... thought maybe you had a way to test it without hooking everything back up. Like with a continuity tester or something.
Thanks for the help.
jchal3 is offline
post #97 of 301 Old 11-06-2019, 10:54 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Just don't leave your ignition on for a long time when testing it.
It could burn out the ICM or ignition coil.
It should work in Accessory mode I think.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #98 of 301 Old 11-11-2019, 04:40 AM Thread Starter
jchal3
1934 CJ7
I put the dash back in today. And turned the key to on. And the turn signals work, imagine that haha.
jchal3 is offline
post #99 of 301 Old 11-11-2019, 04:44 AM Thread Starter
jchal3
1934 CJ7
I'm on to the next issue. The wiper motor was not installed when I got the jeep, so I'm not really sure what state the components were in when I got them, but I have reinstalled them and the wipers arent working. Can anyone help me understand the wiper circuit. It had a funny fuse / circuit breaker in the wiper outlet o the fuse box. I am led to believe that this plastic relay looking thing goes to it too. Any info on what these parts are and what they do would be helpful. Thanks
jchal3 is offline
post #100 of 301 Old 11-11-2019, 05:04 AM
John Strenk
1976 CJ5
Yep, that's the circuit breaker for the wipers.
But there is no "Relay" for the wipers. There is a controller for the delay wipers.
Name:  Wiper Delay and switch.jpg
What you are looking ar appears to be a horn relay or possibly fog light relay
How many wires run to it?
Are they black and grey or more?
post #101 of 301 Old 11-11-2019, 05:11 AM Thread Starter
jchal3
1934 CJ7
Is it possible I dont have delay wipers?
jchal3 is offline
post #102 of 301 Old 11-11-2019, 05:12 AM Thread Starter
jchal3
1934 CJ7
And its 3 wires...big red, green with white, and orange with black
jchal3 is offline
post #103 of 301 Old 11-11-2019, 05:16 AM
John Strenk
1976 CJ5
It's possible.
Try turning your switch.
If you just have 3 positions. Off, low, High then you don't
But if there is a area where the switch rotates without encountering any stops then you probably have the delay wiper switch with the module missing.
I can't remember but I think if you can turn the switch CCW from off and rotate it, then you have delay wipers. But it's been a couple of years since I ran mine.
post #104 of 301 Old 11-11-2019, 05:17 AM
John Strenk
1976 CJ5
That's the horn relay.
post #105 of 301 Old 11-11-2019, 05:37 AM Thread Starter
jchal3
1934 CJ7
It's possible.
It's only 3 positions. So the only items in the circuit are the switch, the motor, and the circuit breaker...correct??
jchal3 is offline
