1981 Kentucky CJ7 build - Page 20 - JeepForum.com
 30Likes
post #286 of 301 Old 09-24-2020, 06:24 PM Thread Starter
jchal3
1934 CJ7
Originally Posted by JoonHoss View Post
Right on!
Hoss
Thanks
Tomorrow we get a new steering damper, rod ends, and maybe brake lines....gas tank and skid plate refurb are next week
Sent from my SM-N960U using Tapatalk
jchal3 is offline
post #287 of 301 Old 09-26-2020, 04:16 AM Thread Starter
jchal3
1934 CJ7
Front end is complete.
JoonHoss and STJP like this.
jchal3 is offline
post #288 of 301 Old 09-26-2020, 04:17 AM Thread Starter
jchal3
1934 CJ7
Does anyone know how to adjust the steering gear to take the play out of the steering? The input side of the steering gear is a little sloppy.
jchal3 is offline
post #289 of 301 Old 09-26-2020, 08:24 AM
cjoffroad
cjoffroad's Avatar
1980 CJ7
It's in the FSM steering section.
cjoffroad is offline
post #290 of 301 Old 09-26-2020, 04:28 PM Thread Starter
jchal3
1934 CJ7
Thanks cj
cjoffroad likes this.
jchal3 is offline
post #291 of 301 Old 09-28-2020, 03:42 PM
agear
Thanks cj
Do you have power steering ? If you do I wouldn't bother I'd just get a new heavy dufy steering shaft
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #292 of 301 Old 09-29-2020, 05:10 PM Thread Starter
jchal3
1934 CJ7
I do have power steering. How would the new shift help?..im assuming the play is in the steering gear itself...am I wrong??
jchal3 is offline
post #293 of 301 Old 09-30-2020, 09:02 AM
81BatmanJeep
1981 CJ7
Question guessing
I think he is implying that rather than repairing what you have just go ahead and upgrade the whole shaft which will include the necessary parts to replace/eliminate the sloppy play and worn out issues.
81BatmanJeep is offline
post #294 of 301 Old 09-30-2020, 01:26 PM
agear
I'm not sure but I think it did on mine. I replaced that lower bearing at the firewall and the shaft and it tightened things up
agear is offline
post #295 of 301 Old 09-30-2020, 05:26 PM Thread Starter
jchal3
1934 CJ7
Okay I get what you guys are saying, but you don't have all the info..i should have explained better...right now the only thing installed in the jeep is the steering gear...i lightly put a pair of vise grips on the input side of the gear to see how things looked when I moved it...i had recently rebuilt the steering gear and installed the whole front end, so i wanted to make sure it kind of worked at this point....that is where I noticed the play. So the steering shift and colum, and bearings, and all that stuff aren't hooked up yet....maybe the amount of play im seeing at this stage is normal??
jchal3 is offline
post #296 of 301 Old 10-10-2020, 06:19 PM Thread Starter
jchal3
1934 CJ7
In the process of cleaning up the 304 for paint. I am the grim reaper to engines, so im trying to touch as little as possible, but i want to really clean it up just the same. I have removed the valve covers, intake manifold, and oil pan. What is the best thing to use to clean out inside of those areas. I was told it looks really good mechanically,but I want to wipe it down to get any debris taken care of...
Here's a couple pics
JoonHoss likes this.
jchal3 is offline
post #297 of 301 Old 10-16-2020, 03:17 PM Thread Starter
jchal3
1934 CJ7
Getting the 304 cleaned up
jchal3 is offline
post #298 of 301 Old 10-16-2020, 07:49 PM
Jim1611
Jim1611's Avatar
Did you go with rubber shackle bushings?
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #299 of 301 Old 10-18-2020, 02:26 PM Thread Starter
jchal3
1934 CJ7
No, they ended up being urethane. I thought they were rubber when I bought them.
jchal3 is offline
post #300 of 301 Old 10-18-2020, 04:06 PM
Jim1611
Jim1611's Avatar
You're going to need to keep the lubed for them to work as designed. I see your bolts aren't fitted for that so you can do so by just taking them apart occasionally and applying some synthetic grease.
My build thread
Jim1611 is offline
