1981 Kentucky CJ7 build - JeepForum.com
 9Likes
post #1 of 200 Old 10-02-2019, 07:23 PM Thread Starter
jchal3
1934 CJ7
Well, I guess here it starts. A lot of you guys have been helping me identify my jeep, and what I am working with on another thread. I plan to use this thread throughout my build to help document what I am doing as well as get advice from the members of this forum.
Be Warned.....I am very new to working on automobiles. I build machinery on a daily basis, but havent ever worked on cars.
The basics:
1981 CJ7
AMC 304 V8
Edelbrock performer 600 CFM carb (newly installed, and not yet tuned)
3 speed manual t150 transmission
Here are some pictures of where I am starting out.
Sent from my SM-N960U using Tapatalk
jchal3 is offline
post #2 of 200 Old 10-02-2019, 07:27 PM Thread Starter
jchal3
1934 CJ7
I put all new belts on today..one ran around the crank, fan, and alternator. The other ran around the crank, fan, and power steering. The one around the power steering looks like it should have two belts but only one was there when I got the jeep. I put two on, but they didnt tension evenly, so now I'm wondering if it should only be one belt. So which is it. One belt or two around the crank, fan, and power steering pump.
Thanks
jchal3 is offline
post #3 of 200 Old 10-02-2019, 07:27 PM
JoonHoss
JoonHoss's Avatar
2011 JK Wrangler
Pulling up a virtual barstool in the corner of your shop...
Carry on my good man!
Hoss
Azhunter1 likes this.
Good judgement comes from experience; experience comes from bad judgement
JoonHoss is online now
post #4 of 200 Old 10-02-2019, 07:31 PM Thread Starter
jchal3
1934 CJ7
There's beer in the fridge grab one hoss..thanks for the help so far
jchal3 is offline
post #5 of 200 Old 10-02-2019, 08:14 PM
Hoover7
Hoover7's Avatar
Move over a spot, Hoss. And pass me one of those beers.
Hoov
82 CJ7 Laredo Ltd, 258, T5, frame off resto/rebuild planned
83 CJ8 Scrambler, 360, T176, EFI, in progress
84 CJ7 Renegade, 258, T5, Weber 38, Cliffordized, Borla headers
Hoover7 is offline
post #6 of 200 Old 10-02-2019, 10:04 PM
MetalMountainGoat
MetalMountainGoat's Avatar
This thing doesn't look all that bad considering you just got it. It doesn't appear to be plagued with PO issues other than those terrible TSL ThornTurds. A good cleaning would really make this thing look a lot better and uncover some issues that you may possibly need to address first. Good luck with build. These CJs are fun and cheap to rebuild. This forum and the people on it will be all the help you will ever need during this process.
MetalMountainGoat is offline
post #7 of 200 Old 10-03-2019, 07:27 AM
bob4703
1974 CJ5
No Dog Beers Joon!
JoonHoss likes this.
Paved roads are prime examples of government over spending!
bob4703 is offline
post #8 of 200 Old 10-03-2019, 07:36 AM Thread Starter
jchal3
1934 CJ7
Hey before you guys empty my fridge will one of you answer my belt question hahah you know.... before 2 belts becomes 4 hah
jchal3 is offline
post #9 of 200 Old 10-03-2019, 08:53 AM
JoonHoss
JoonHoss's Avatar
2011 JK Wrangler
You should only need one belt. The second groove was likely for an additional accessory belt, and went to (for example) an AC compressor or smog pump
Hoss
post #10 of 200 Old 10-03-2019, 08:57 AM
Hoover7
Hoover7's Avatar
Thanks
Have an image? I haven't seen a set up with two belts going around the PS, but have seen two belts run the alternator and the AC compressor (when present). One belt should be fine-
Hoov
Hoover7 is offline
post #11 of 200 Old 10-03-2019, 08:58 AM Thread Starter
jchal3
1934 CJ7
I'll get a pic in a few
jchal3 is offline
post #12 of 200 Old 10-03-2019, 09:10 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Looks like a good base to start with. I'm an ex mechanic with no real body experience, so anything with a solid tub is with me.
Be sure to slant you build to your proposed use. A lot of guys sit with an offroad mag between there thighs and stare at the glossy pictures while ordering a bunch of totally useless crap. Put together a build sheet to chart what you need and to keep you on track.
I like to group my work so I don't have to go back two or three times.
IE rear axle complete. This includes all brakes, springs, and bushings.
Front axle complete. Includes all above and any steering components.
Engine, transmission, t case complete.
ETC.
Originally Posted by JoonHoss View Post
You should only need one belt. The second groove was likely for an additional accessory belt, and went to (for example) an AC condenser or such.
Hoss
Many times the second groove ran an AIR pump.
That being said, you should be able to run two belts. This was not an uncommon set up on older luxury cars, usually on the AC. If the belts are the same size and from the same manufacture, they should be able to be tightened without any issues.
The duty of a patriot is to protect his country from it's government
Thomas Payne
jeepdaddy2000 is offline
post #13 of 200 Old 10-03-2019, 09:21 AM
Hoover7
Hoover7's Avatar
Yep, had forgotten about the smog pump running off the PS pump. Haven't seen one of those for a long time.
Hoov
Hoover7 is offline
post #14 of 200 Old 10-03-2019, 09:35 AM
Deer-Slayer_5
Deer-Slayer_5's Avatar
Pretty sure I saw this one on the marketplace while searching for parts lol looking forward to seeing your build!
CJ-7 build
Deer-Slayer_5 is offline
post #15 of 200 Old 10-03-2019, 09:45 AM Thread Starter
jchal3
1934 CJ7
That's where I got it....4 hours from home...got it on a trade
jchal3 is offline
