1980 Jeep CJ5 shifter gets stuck - JeepForum.com
post #1 of 2 Old 04-18-2019, 01:59 PM Thread Starter
yaboigee
Hey guys,
I am new here and recently purchased a 4 speed manual transmission 1980 CJ5 with only 59k miles on it. I do not have much knowledge when it comes to vehicle engines, so bear with me as I further learn.
The main problem I am having right now is 1 out of 3 times I take it out for a drive my shifter gets stuck. So I take off in first gear then attempt to shift to second gear but it wont go into gear and stays in neutral. The only solution I have for it is wiggling the shifter all the way to Reverse then come back and I am able to shift into second gear. This seems to mainly happen in between 1st and 2nd gear.
Not sure if it is a clutch problem or transmission issue.
Thanks!
yaboigee is offline
post #2 of 2 Old 04-18-2019, 07:40 PM
John Strenk
John Strenk's Avatar
1976 CJ5
If it's a t-176 it's a common problem with a worn shift lever.
Many posts on this.
https://www.google.com/search?q=t-17...hrome&ie=UTF-8
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
cj5 , clutch issue , shifter , shifter linkage
My goal is to get 25+ mpg from my 99 XJ with 30 x 9.5 R15 ATs Charley3 XJ Cherokee Technical Forum 3864 10-19-2019 10:58 PM
1980 Jeep CJ5 27,800 Original Miles gregd_34668 Jeeps For Sale 0 07-18-2018 08:55 PM
cj5 jeep Lee48 Jeep CJ Forum 0 07-09-2018 06:52 PM
1980 CJ5 Cold Start swood918 Jeep CJ Forum 3 06-24-2018 11:24 AM
How to install an RB1 navigation unit in a 1997-2001 Jeep Cherokee Country Jeep XJ Cherokee Technical Forum 14 01-21-2018 04:43 PM
