1980 CJ7 speedometer slow - JeepForum.com
post #1 of 9 Old 06-15-2019, 07:53 PM Thread Starter
clarkg
1978 CJ5
I recently bought a 1980 CJ7 with a 4.2L and T176. The speedometer runs really slow. At 60mph it registers about 45.
The odometer seems to be registering correctly.
Should I take the speedometer apart and try to clean and lubricate it?
Any ideas on what to look for?
clarkg is offline
post #2 of 9 Old 06-16-2019, 04:59 PM
popascj7
1976 CJ7
Have you checked to make sure you have the correct speedometer gear installed for your gear ratio and tire size?
popascj7 is offline
post #3 of 9 Old 06-16-2019, 05:44 PM Thread Starter
clarkg
1978 CJ5
No I havenít checked this. I did check the odometer against mm posts and it seems correct.
Just thinking that if my odometer is correct the problem must be that there is too much friction in the speedometer needle pivot.
Is there an easy way to check the gear ratio?
clarkg is offline
post #4 of 9 Old 06-17-2019, 02:12 PM
CJeep82
CJeep82's Avatar
1982 CJ5
There are a couple ways to determine gear ratio. First would be to count the number of teeth on the ring gear and pinion then divide them. The other way that doesn't require opening the diff would be to spin the drive shaft with the Jeep in the air and count the number of times the driveshaft revolves for every complete revolution of the tire. If the tire makes 1 complete revolution and the pinion spins 3.5 times, you would have 3.54. If the pinion spins a little over 4 times then you have 4.10 and so forth.
CJeep82 is offline
post #5 of 9 Old 06-18-2019, 06:55 AM
bob4703
1974 CJ5
If the odometer is right and the speedometer isn't then the gear is good or at least isn't the culprit. Both run from the speedometer cable. Sounds like it is time for a new speedometer assembly or a rebuild of the present one. Good luck!
Paved roads are prime examples of government over spending!
bob4703 is offline
post #6 of 9 Old 06-20-2019, 06:13 PM
80cj
80cj's Avatar
1980 CJ5
Mine went south a few days ago also. Ordered an Omix one. I'll find out how good it is.
80cj is offline
post #7 of 9 Old 06-20-2019, 06:44 PM
John Strenk
John Strenk's Avatar
1976 CJ5
I think the ratio of 1000 rpm :60 mpg is what most speedometers are set up for.
If you have a 1000 rpm drill you can check the accuracy of the speedometer.
You might be able to adjust them somehow. it's just a spinning magnet in a cup (Or maybe the cup is the magnet) held back by a spring.
John Strenk is offline
post #8 of 9 Old 06-20-2019, 10:59 PM
80cj
80cj's Avatar
1980 CJ5
John, I was meaning to ask you about the workings of a speedo. So 1000 RPM=60MPH? I don't know what the heck is wrong with mine. It really lags as I accelerate, then as I settle in at a steady speed it seems to catchup.
80cj is offline
post #9 of 9 Old 06-21-2019, 05:22 AM Thread Starter
clarkg
1978 CJ5
I was wondering about cleaning and lubricating the mechanism that drives the needle. Since my odometer seems to be working, i am thinking that the needle must not be moving freely and thus is prevented from traveling as far as it should.
Wondering if anyone else has tried this?
clarkg is offline
