1980 cj5 - JeepForum.com
 5Likes
post #1 of 35 Old 02-28-2019, 10:24 PM Thread Starter
mwaym3
1980 cj5
I made a deal for a 1980 CJ5... 4 cyl... manual trans.... no top.... Body isn't perfect, but decent... Motor runs and 4wd works..... Tires are good.. BFG... We just wanted a play jeep... a CJ for summer.... $1500.... Good deal or no ??
mwaym3 is online now
post #2 of 35 Old 02-28-2019, 10:26 PM Thread Starter
mwaym3
post #3 of 35 Old 02-28-2019, 10:52 PM Thread Starter
mwaym3
post #4 of 35 Old 02-28-2019, 10:56 PM Thread Starter
mwaym3
post #5 of 35 Old 02-28-2019, 10:59 PM Thread Starter
mwaym3
post #6 of 35 Old 02-28-2019, 11:06 PM Thread Starter
mwaym3
post #7 of 35 Old 02-28-2019, 11:10 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
1500 and it runs? Yes, great deal. If you want a summer cruiser and hit a few trails, it is perfect!!!
I would take out any carpet, patch the floors, add seat covers and put on a bikini top for $60 to keep the sun off. If it has not been serviced, I would also drain all fluids and replace spark plugs and leads etc.
trailhead2004 likes this.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #8 of 35 Old 02-28-2019, 11:55 PM Thread Starter
mwaym3
That's exactly what I was thinkin..... Thanks for the reply !!!
post #9 of 35 Old 03-01-2019, 12:00 AM Thread Starter
mwaym3
Would love to have a top for winter, but we have 2 F150 4x4s for that.....
post #10 of 35 Old 03-01-2019, 12:06 AM Thread Starter
mwaym3
I was thinkin, some do it yourself bedliner, instead of carpet........ Just to make it easy and durable
post #11 of 35 Old 03-01-2019, 01:08 AM
BagusJeep
BagusJeep's Avatar
1981 CJ7
Bedliner requires a sound rust free surface or it allows rust creep, so it needs prepping properly. Having said that, you could prep and paint in a day and it looks good when first applied.
Whole area needs wire wheeling back to good metal or sound paint and then rust treatment where needed before you scuff for the bedliner. Just beware of what is under the roll bar feet, they did not paint it before they put the roll bar in so you should pull the roll bar and repair and bedline and put the roll bar back in if you do not want it to peel in this area.
post #12 of 35 Old 03-01-2019, 07:39 AM Thread Starter
mwaym3
Okay.... Thank you for the info....
post #13 of 35 Old 03-01-2019, 08:14 PM
Sparkybob
1978 CJ5
Sweet deal!!! Lotta room for upgrades....
mwaym3 likes this.
Too bad stupidity isn't painful.
Sparkybob is offline
post #14 of 35 Old 03-01-2019, 08:29 PM Thread Starter
mwaym3
I think so... we were looking to get in cheap, and keep it simple...
post #15 of 35 Old 03-02-2019, 06:26 AM
HackFabrication
HackFabrication's Avatar
1976 CJ5
Good deal for a running CJ. If it hasn't been tampered with, it has the GM 151 (2.5L) Iron Duke 4 cyl and a SR4 4 speed transmission (the T5 5 speed wasn't available until 1982, IIRC), mated to a Dana 300 transfer case. Dana 30 front axle, AMC 20 rear axle. Weak links would be the SR4 transmission, but behind a 4 banger, it should be okay if you don't abuse it. The AMC 20 has two piece axle shafts, which also shouldn't be a problem behind a 4 banger. Check for the correct transmission oil. IIRC, AMC altered it from auto trans fluid to another type of gear lube. Someone here, with more knowledge, will set you on the right path. I wouldn't run anything larger than a 32" tire on it. 31" would be great on a stock suspension CJ5 with manual brakes and steering. Going up in tire size can create a bunch of issues, which translate into $$$.
Swap out all the fluids. Including the brake fluid. And enjoy it. Fix it when it breaks, and keep going. Don't get rid of the top frame that I see. There are always people looking for parts. A new BesTop Supertop is going to run you over $800 (which includes frame, etc.). If you're only going to use it in the summer, I agree in just getting a bikini/Bimini top for it.
mwaym3 likes this.
"In the end...It's all Hack."
HackFabrication is offline
mwaym3
1980 Jeep CJ5 27,800 Original Miles gregd_34668 Jeeps For Sale 0 07-18-2018 08:55 PM
1980 CJ5 Fuel Lines swood918 Jeep CJ Forum 3 06-24-2018 12:14 PM
1980 Navy Cj5 TinCanMan Jeep CJ Forum 4 06-24-2018 05:59 AM
1980 Jeep CJ5 rebuild/project. What’s missing from this engine? Lecho Jeep CJ Forum 14 06-18-2018 09:01 AM
1980 cj5 doors and top question Phippsjimmy Jeep CJ Forum 9 06-06-2018 03:03 PM
