1980 bulkhead connector picture - JeepForum.com
 3Likes
post #1 of 16 Old 04-18-2018, 07:06 PM Thread Starter
texasdave
texasdave's Avatar
1980 CJ7
Hope this helps someone. I traced each wire and then matched number from bulk head connector.
texasdave is offline
post #2 of 16 Old 04-18-2018, 07:29 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Must be an Early 80. Looks the same as the 79 Bulkhead connector
I thought the 80 had more connectors
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is online now
post #3 of 16 Old 04-19-2018, 08:32 AM Thread Starter
texasdave
texasdave's Avatar
1980 CJ7
^^ That's what I'm thinking. When I started rewiring it did not match the 80-83 diagram. I haven't checked the VIN to see when it was made. Note the picture I posted does not have "E" or "F". Also 1980 was another transitional year where AMC made some changes to include the Dana 300 that is different internally than the later Danas.
John Strenk likes this.
post #4 of 16 Old 12-27-2018, 11:57 AM
onemanarmy
so why did you post it, labeled incorrectly, if you knew it wasn't for an 80?
really screws up google searches, which is why I'm here. A google search for a 1981 connector.
onemanarmy is offline
post #5 of 16 Old 12-27-2018, 12:14 PM
John Strenk
1976 CJ5
This help? 1980 to 1986 Bulkhead connector
There were only two types used from 76 to 86
Must be one or the other.
post #6 of 16 Old 12-27-2018, 12:19 PM
trailhead2004
trailhead2004's Avatar
1980 CJ7
Looks like the one in both of my 1980 CJs as well as the diagrams in theFSM.
trailhead2004 is offline
post #7 of 16 Old 12-27-2018, 12:24 PM
trailhead2004
1980 CJ7
John, maybe you can explain why both my 80ís have the same connector as the OP posted but you are showing a much larger one.
Not sure if it would make a difference or not, but my 7 is a 258 rig and my 5 was originally a four banger. Plus, mine matching the FSM. Is it possible the larger connector was put in late 1980 units?
post #8 of 16 Old 12-27-2018, 12:31 PM
John Strenk
1976 CJ5
That's why I was wondering it it was an early 1980 make.
Mid 1979 they made some major changes to the wiring harness.
It's tricky to get the right parts for a 79 CJ.
I was thinking they may have continued to use the 79 parts into early 1980.
You have a 1980 Schematic out of the FSM?
I only have one that shows the bulkhead connector and I don't think it's out of a FSM.
If you can, post it up here as that will clear up a lot of mystery.
post #9 of 16 Old 12-27-2018, 12:52 PM
onemanarmy
kinda.
The 'upshift' light is not a thing on CJs, I don't believe. YJ's have it. That connector is used for a main power wire on other CJ diagrams I've seen.
post #10 of 16 Old 12-27-2018, 12:53 PM
trailhead2004
1980 CJ7
For your reading pleasure. Came from a 1980 Jeep Factory Service Manual. Three page foldout at the back of the book. There is a second set in there for the Cherokees and other FSJ's.
I cut out the V8 portion from the picture to avoid confusion on my part since I have a 258 in my 7, but if anyone needs it I can post it. Part of the problem is that it bridges what I call Sheet 1 and Sheet 2.
1980 CJ Schematic Sheet 1 Edit 1.jpg   1980 CJ Schematic Sheet 2 Edit 1.jpg   1980 CJ Schematic Sheet 3 Original.jpg
post #11 of 16 Old 12-27-2018, 12:59 PM
HAZCAT
HAZCAT's Avatar
My '84 CJ has the larger style bulkhead connector.
'84 CJ7, 44, 14 bolt, twin stick 300, 109"whl base, 4 linked
'93 XJ Cherokee
'70 CJ6 Dauntless v6
HAZCAT is offline
post #12 of 16 Old 12-27-2018, 01:15 PM
John Strenk
1976 CJ5
Excellent!!
Now to update everything....
post #13 of 16 Old 12-27-2018, 01:22 PM
onemanarmy
Thanks
Sent from my Moto G (4) using Tapatalk
post #14 of 16 Old 12-27-2018, 02:07 PM
HAZCAT
HAZCAT's Avatar
kinda.
Upshift was on the CJ models but only on 4cyl models. That is a power wire on the 6cyl models but not the main power wire which is a 10 gauge wire in spot EY.
'93 XJ Cherokee
HAZCAT is offline
post #15 of 16 Old 12-27-2018, 02:35 PM
John Strenk
1976 CJ5
Exactly:
