1978 T150 Challenges - JeepForum.com
 2Likes
post #1 of 18 Old 06-23-2020, 10:12 PM Thread Starter
aficio
1978 CJ7
I have been going through my 1978 T150. when I put in the mainshaft retaining snap ring it was loose, so I held it and thought I would use a hammer and bend it back a little tighter. Well, I lightly hit it once and it split in half. So I think, I will just buy a new one. I have been unable to find the actual part number for that item. Going through more diagrams that I can remember. I have yet to see a listing with the actual part number for that item. I tried the J8124935 but it just hangs on the shaft because it is so oversized. I also saw a site that said it was the 8126813, which is the front bearing retainer snap ring. Does anyone know the actual part number for the "mainshaft Retaining snap ring"? In most service manuals it is listed and 1 in the parts diagrams.
Thank You
aficio is offline
post #2 of 18 Old 06-23-2020, 10:46 PM
Hurricane4
Hurricane4's Avatar
1979 CJ5
This?
https://www.quadratec.com/p/crown-au...-cj-5-and-cj-7
uptillnow likes this.
"The unbelievable we can do immediately . . . the impossible just takes a little longer."
My College Accounting Professor
"Success is not final. Failure is not fatal. It is the courage to continue that counts"
Winston Churchill
Jeeps I Have Owned in Year Order:
'61 CJ5, '63 CJ6, '78 CJ5, '79 CJ5 (Current), '79 CJ7 & '86 CJ7.
Hurricane4 is offline
post #3 of 18 Old 06-23-2020, 10:49 PM
Hurricane4
Hurricane4's Avatar
1979 CJ5
Also here:
https://somarmotor.com/snap-ring-main-shaft-en-2/
J8124934
Winston Churchill
post #4 of 18 Old 06-24-2020, 08:01 AM Thread Starter
aficio
1978 CJ7
I will give it a shot. thank you.
aficio is offline
post #5 of 18 Old 06-26-2020, 02:16 PM Thread Starter
aficio
1978 CJ7
Still not a winner. Just had my new clips dropped off, the J8124934 and they like the J8124935 and the 8126813 are not the right part number. Does anyone have a factory parts manual for a 78 T150 they would reference.
Thank You
aficio is offline
post #6 of 18 Old 06-26-2020, 02:24 PM
Hurricane4
Hurricane4's Avatar
1979 CJ5
Sorry - Thought those were it.
Winston Churchill
post #7 of 18 Old 06-26-2020, 03:23 PM
Jafo220
Thank You
You might try calling Novack. They also sell trans parts. They may be able to get you what you need over the phone.
Jafo220 is offline
post #8 of 18 Old 06-28-2020, 09:56 PM Thread Starter
aficio
1978 CJ7
Will call tomorrow.
Thanks
aficio is offline
post #9 of 18 Old 07-01-2020, 08:11 AM Thread Starter
aficio
1978 CJ7
Novak like all the others only has it in a small parts kit. It must be one of those parts that is hardly ever replaced on it's own, so not one has ever had to research it. If I did not have the transmission done I would pickup the small parts kit, I did not believe it would be this difficult to figure out.
aficio is offline
post #10 of 18 Old 07-01-2020, 04:24 PM
jchal3
1934 CJ7
I might be able to help you out. I just rebuilt my t150. I think the old parts are still laying around. Send me a pic. And if I've got it I'll mail it to ya
Sent from my SM-N960U using Tapatalk
aficio likes this.
jchal3 is offline
post #11 of 18 Old 07-02-2020, 03:52 PM Thread Starter
aficio
1978 CJ7
I appreciate it. I added a pic, but not with a ruler or dial caliper next to it. it looks to be .092 thick the ID is around 1.305 being broken it is just somewhere in that range. The width of the ring is .163 and the outside diameter is around 1.682.. I really appreciate the help. I found what may work but it is a manufacture and cannot find it at any retailers.
Thanks
Aficio
27976 N. Quartz Drive
San Tan Valley AZ
85143
aficio is offline
post #12 of 18 Old 07-02-2020, 03:54 PM
jchal3
1934 CJ7
I appreciate it. I added a pic, but not with a ruler or dial caliper. next to it. it looks to be .092 thick the ID is around 1.305 being broken it is just somewhere in that range. The width of the ring is .163 and the outside diameter is around 1.682. I will PM my address. I really appreciate the help. I found what may work but it is a manufacture and cannot find it at any retailers.
Thanks
Aficio
Cool I'll look when I get to work tomorrow (that's where my jeep is) I broke one when I was taking it apart, but I dont think it was the one you need.
jchal3 is offline
post #13 of 18 Old 07-02-2020, 04:41 PM
JEEPFELLER
JEEPFELLER's Avatar
1977 CJ5
Rural hoarder type transmission shop or ole time auto salvage yard with '60s and '70s Ford pickup trucks, some of 'em had T-150s (2WD) with a tailshaft on the back end. Sometimes you can find the trannys taken apart ready to scrap out (not needing to buy the whole deal).
----JEEPFELLER
JEEPFELLER is offline
post #14 of 18 Old 07-02-2020, 05:59 PM
80cj
80cj's Avatar
1980 CJ5
Since you're doing a rebuild, you probably need a small parts kit. Why don't you purchase the kit Novak has?
80cj is offline
post #15 of 18 Old 07-03-2020, 05:04 AM
jchal3
1934 CJ7
Thanks
Aficio
San Tan Valley AZ
85143
I think I have what you need . The Id and od dont match but are close so I am assuming it's because your is broken and mine is not. But the other measurements match.
jchal3 is offline
