1977 cj7 roll bar bolts ? - JeepForum.com
post #1 of 7 Old 08-21-2018, 06:43 PM Thread Starter
BushPusher77
1977 CJ7
Cj 1977 cj7 roll bar bolts ?
I have a 1977 cj7 that I am gathering parts for so I can fix it up and I was wondering if anyone knows where I can find 1 of the roll bar bolts. Its the roll bar that sits on top of the wheel wells and their are 8 bolts going through the body and I am missing just 1.
I have looked around with no luck, so any help with this would be great..
Thank You Roger
Update to information
the bolt takes a Torx t45 bit, it is a button head bolt with a 3/4' dia.
head its 2" long fully threaded with 3/8"-16 threads
the bolt goes through the tub then a spacer and through the lower angle of the roll bar.
I do not have any of the bolts that go through the roll bar and fender wells if some one had a picture of one that would also help out so I know what I am looking for
BushPusher77 is offline
post #2 of 7 Old 08-22-2018, 04:55 AM
keith460
Jeep. There's Only One
keith460's Avatar
Torx Head?
It would help if you describe what type it is you seek. Length, thread size, head of bolt type, fully threaded or partial, etc.
1984 CJ-7 Renegade
keith460 is online now
post #3 of 7 Old 08-22-2018, 06:00 AM Thread Starter
BushPusher77
1977 CJ7
i will do that in a few hours, get a picture alone with size length
post #4 of 7 Old 08-22-2018, 06:05 AM
jp360cj
1977 CJ7
Is it the bolt going through the side of the tub, or down through the fender well?
I replaced mine with button head allen screws from the hardware store. If you want to stay with the torx head, then I would pull one out and see what size you need, then check McMaster Carr or similar.
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #5 of 7 Old 08-22-2018, 08:05 AM
Bmann412
Bmann412's Avatar
1930
I might have a spare bolt I bought a new set of torx bolts for my roll bar.
Sent from my iPhone using Tapatalk
1998 TJ 5.9l
1978 CJ7 Renegade
2013 JK
Bmann412 is online now
post #6 of 7 Old 08-22-2018, 09:29 PM
CSP
Unless you're doing a factory restoration it's a great time to go to either a hex head or allen head.
CSP is offline
post #7 of 7 Old 09-03-2018, 07:56 PM Thread Starter
BushPusher77
1977 CJ7
no one has one of these bolts kicking around they would part with
