1976 CJ7 rear end gear ratio. - JeepForum.com
post #1 of 8 Old 09-07-2009, 09:21 PM Thread Starter
PIPER-68
1976 CJ7
I have a 1976 CJ7 that I just got . It was originally a Quadratrac but the front axle appears to have lock out hub on it that were missing and the front drive shaft was removed . I was told maybe someone put in the wrong gear ratio on the replaced front axle and they couldnt make it work so they just took the drive shaft and lock outs off . My question is the front axle has a tag on it stating 3 73 which I assume is the ratio the rear axle has no tag but appears to be original . Dose anyone know what the correct gear ratio would have been on the rear axle ? It is a 304 V8 with an automatic trans.
Thanks for your help.
Chad...
PIPER-68 is offline
post #2 of 8 Old 09-07-2009, 09:46 PM Thread Starter
PIPER-68
1976 CJ7
I read the simular threads and answered my own question I think . My front axle says 3 73 my rear axle has the stamp ( A ) on it and guess that means I have a 3:54 open on the rear . This won't work very well will it ?? That is probably why it was disconnected when I bought it . Am I right in my thinking on this ?
Thanks,
Chad...
PIPER-68 is offline
post #3 of 8 Old 09-08-2009, 09:12 PM
John N
1981 CJ8
Thanks,
Chad...
Sounds like you've figured it out. Now you'll get to straighten out the mess.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #4 of 8 Old 09-09-2009, 09:15 PM Thread Starter
PIPER-68
1976 CJ7
Got lucky and found a good complete 3:54 axle only 20 miles away . It is off a year or two later model with disc brake's ( a real plus ) and he had the rear axle a straight six engine still hooked to a th400 auto trans and the Quadratrack transfer case with a low range and both drive shafts . So I bought it all . If you know anybody looking for a good complete straight 6 engine I am selling it , They say it only has 40k on it but can't confirm . I will keep the rest for spare's.
PIPER-68 is offline
post #5 of 8 Old 09-09-2009, 10:01 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
I know it is too late, but always drop the covers and do a tooth count. Many times PO's will do gear swaps and there is no way to tell short of actually counting the teeth. This also gives you an excuse to change the fluids and do a carrier inspection.
jeepdaddy2000 is offline
post #6 of 8 Old 09-10-2009, 03:17 AM
jokenring
1974 CJ5
Adding to what jeepdaddy said, stamped on the ring gear is the tooth count for the ring and pinion. 41 11 is 3.73 and 46 13 would be 3.54. Divide the ring gear tooth count (46) by the pinion tooth count (13). Good thing to do whenever buying axles. Don't believe what the seller says. Verify for yourself. I learned the hard way.
jokenring is offline
post #7 of 8 Old 09-10-2009, 06:31 AM
alex211
alex211's Avatar
1995 XJ Cherokee
Do you still have the quadratec transfer case?
95 xj bone stock for now
alex211 is offline
post #8 of 8 Old 09-10-2009, 08:15 AM Thread Starter
PIPER-68
1976 CJ7
Yes , but i plan to keep it for a spare or at least till I get mine back on the road and make sure everything works as it should .
PIPER-68 is offline
84 CJ7 gear ratio garoughrider Jeep CJ Forum 12 03-24-2007 05:54 AM
Rear end gear ratio 84cj7 steve84cj7 Jeep CJ Forum 2 02-02-2005 08:58 PM
1.45:1 rear gear ratio? fromme Jeep CJ Forum 3 01-11-2005 03:55 PM
stock gear ratio for 1976 certifiablejeep Jeep CJ Forum 2 08-21-2004 02:38 PM
)))))rear gear ratio?((((((((((help! 2cjs Jeep CJ Forum 11 02-25-2002 06:20 PM
