1975 cj5 wiper motor install - JeepForum.com
 1Likes
post #1 of 24 Old 09-04-2020, 08:18 AM Thread Starter
nvmycj5
New guy here and first post. I apologize if it's in an incorrect forum, and I'm sorry about my "novice-ness!"
I'm trying to install a new wiper motor. Let me preface this by saying, it was a BEAR getting the nuts and bolts off of the windshield frame. Oi vey!!! Damn things broke right off!
It's a three wire motor. No pump. I'm even having a bear trying to take off the switch off the dash. (Stop laughing!)
I'm seeing switches with 5 prongs. Is this the one I need, or do I need one with a three prong? I've googled and amazon'd the switch and they've all got 5 prongs.
thanks!
nvmycj5 is offline
post #2 of 24 Old 09-04-2020, 11:08 AM
Fldvr
Fldvr's Avatar
1974 CJ5
It might have 5 poles but you only need the 3. Use a DVM when you get the switch to check. Is it a rotary switch? You may end up with dead spots on the last 2 if it is. You can just jumper them to the 3rd position "high" to avoid confusion. Mine had the multiple positions but I ended up with a 2 position switch, low and high...I don't have a top here in florida so the wipers are really useless for most purposes.
Fldvr is offline
post #3 of 24 Old 09-04-2020, 01:20 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Five is right,
1 power
1 Hi Speed
1 Low Speed
1 Park
1 Washer.
I've seen them square and round bases.
3 positions Off, low, High.
Push for windshield washer pump
Fldvr likes this.
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #4 of 24 Old 09-04-2020, 01:31 PM
Fldvr
Fldvr's Avatar
1974 CJ5
Five is right,
1 power
1 Hi Speed
1 Low Speed
1 Park
1 Washer.
That looks nothing like mine:-) who knows how many times previous owners must of "repaired" it:-)
Sent from my iPhone using Tapatalk Pro
Fldvr is offline
post #5 of 24 Old 09-08-2020, 11:41 AM Thread Starter
nvmycj5
Awesome pics! this will help me!!
Do I have to take off my entire dash panel to get access to the backside? I'm have a hell of a time trying to get the knob off the front.
Thanks so much!
Five is right,
1 power
1 Hi Speed
1 Low Speed
1 Park
1 Washer.
nvmycj5 is offline
post #6 of 24 Old 09-09-2020, 12:56 PM
John Strenk
1976 CJ5
No, You can reach up and take it off.
The knob is trickey.
Not sure if the 75 is the same or not.
post #7 of 24 Old 09-11-2020, 03:59 PM Thread Starter
nvmycj5
this is my knob that I finally removed! No springs or clips.
Now....new problem. I got the new motor and I bought a new switch. I replaced all the previous wires to the same spot as the previous switch. Aaaaaaand,.... nothing. Did I just waste $96 dollars on amazon by getting this new motor???
nvmycj5 is offline
post #8 of 24 Old 09-11-2020, 04:07 PM
Hoover7
Hoover7's Avatar
Is that what the knobs are supposed to look like on a 75 CJ? I've been following your thread and wasn't expecting to see that. Post a few pictures of both your old and new gear, as well as your hook ups. Fuse is good? Sounds like it's time to get the JF electrical gurus on speed dial-
Hoov
82 CJ7 Laredo Ltd, 258, T5, frame off resto/rebuild planned
83 CJ8 Scrambler, 360, T176, EFI, in progress
84 CJ7 Renegade, 258, T5, Weber 38, Cliffordized, Borla headers
Hoover7 is offline
post #9 of 24 Old 09-11-2020, 04:51 PM
John Strenk
1976 CJ5
Make sure itís grounded to the case.
post #10 of 24 Old 09-13-2020, 11:20 AM Thread Starter
nvmycj5
John,
I didn't mount the motor. I just sat in the driver seat and attached all the wires to see if it worked. Should I mount it and then retry?
nvmycj5 is offline
post #11 of 24 Old 09-13-2020, 11:21 AM Thread Starter
nvmycj5
Hoov
I'll check the fuse!
nvmycj5 is offline
post #12 of 24 Old 09-13-2020, 11:22 AM
John Strenk
1976 CJ5
Originally Posted by nvmycj5 View Post
John,
Or attach a ground wire to one of the mounting bolts.
post #13 of 24 Old 09-14-2020, 10:16 AM Thread Starter
nvmycj5
Mounted the motor. Nothing.
Checked the fuse. It doesn't seem blown. Just rusty. The fuse slot is labeled radio/wipers. Radio works, so I don't know. Going to replace the fuse and see what happens.
nvmycj5 is offline
post #14 of 24 Old 09-14-2020, 10:27 AM
John Strenk
1976 CJ5
Do you have a test light?
That will help you in trouble shooting.
You can get them in Walmarts.
If the radio works, and it's on the same fuse then the fuse isn't the problem. Unless the radio was wired up differently than stock.
post #15 of 24 Old 09-15-2020, 05:37 PM
paco1076
repost images please
Five is right,
1 power
1 Hi Speed
1 Low Speed
1 Park
1 Washer.
John - I've b een looking for a picture of the back of the switch for days. Can you repost them? Or email them?
THanks,
Craig
paco1076 is offline
