1974 CJ5 Which Internal Regulated Alternator to upgrade to and how - Page 4 - JeepForum.com
post #46 of 49 Old 10-12-2015, 06:54 PM
Cutlass327
Cutlass327's Avatar
1930 CJ2
I would try to stick to a fusible link wire or I bought a weather proof circuit breaker. I popped my original fusible link when I was winching once - had the rpm set to 1500, 70+A alternator, and about 10' into the pull I lost the charging system.
I don't recommend a fuse, as after a while the connections may become loose/dirty and then the holder heats and fails. Or you get an amp spike and it pops to easily. I'm going to be replacing my headlight fuse soon with a breaker as the terminals have come loose a couple times and I've melted 2 fuses. Corrosion from winter water splashed and loose connections caused some heat. Someday I'll have the time to do the relay upgrade.
Rick
1978 CJ5 5.0HO/T177/D300 TerraLow 4:1 kit, '86 D30/D44 3.54 WT axles w/Aussies, 'glass body, 33x12.5 ProComp A/T, TDK galv'd frame, 2.5 OME YJ lift - DD and weekend toy
Cutlass327 is offline
post #47 of 49 Old 10-13-2015, 05:27 AM
Mike Romain
Fuse link wire is the best way to go. It sells by the foot and needs to be crimped in place, solder damages its properties.
Normally you use a link wire 2 automotive gauge sizes smaller than the wire being protected. So for a stock 10 ga. alternator wire, you use 14 ga. fuse link wire.
Mike
Mike Romain is offline
post #48 of 49 Old 05-16-2021, 07:52 AM
Kowboy84
Kowboy84's Avatar
Good morning all. I see this form is a few yrs old. Hope some of you are still on here and can lend me a hand. I have a 1974 cj5. I also went with the speedway 21 wiring harness. Unfortunately I am not getting any support from them my old wiring harness had caught fire and melted. So I'm trying to figure out where each one of these wires go. I am hooking up the Gray wire from the alternator to the for pin where does it go in the dash. For some reason I cannot open any of the old pictures on this form. Million more questions to ask if you guys are still around thank you for any and all help
Kowboy84 is offline
post #49 of 49 Old 05-16-2021, 10:52 AM
bob4703
1974 CJ5
Follow the Speedway harness instructions. Brown wire off the two wire plug goes to ignition red wire off plug goes to center power stud and then to the battery side of the solenoid with fusible link on battery side. Forget about what was there before.
https://static.speedwaymotors.com/pd...019revised.pdf
Paved roads are prime examples of government over spending!
bob4703 is offline
alternator
