1972 CJ5 with AMC 360 V8 Information - JeepForum.com
 1Likes
post #1 of 16 Old 06-22-2021, 10:03 AM Thread Starter
CrustyCJ5
CrustyCJ5's Avatar
1972 CJ5
Hey guys - I've just picked up a cheap 1972 CJ5, I didn't get a ton of information around it so was looking to get some questions answered, hoping this would be the right place!
My main question is it has an AMC 360 V8, not an AMC 304 or V6 - the previous owner was told it was the original factory engine to the Jeep, is that possible? He mentioned it was rare for them to be fitted with the 360, I'm looking to see how valid this claim might be. I wasn't able to find much info about any CJ5s with factory 360s.
Here's a picture below, not the prettiest (someone painted the entire thing with brushed brown paint, made it look like a rust bucket) but it runs and drives and doesn't need panel work. Any other interesting info about this model, or anything that is a must upgrade (most of it looks original) would be greatly appreciated. Looking forward to this summer project.
Thanks!!
CrustyCJ5 is offline
post #2 of 16 Old 06-22-2021, 11:05 AM
RiverandSand
1980 CJ5
Unfortunately a 360 was never offered in a CJ, 304 was the only V8 offered. It also appears to be a later year model possibly 76 or newer. Is windshield wiper motor on the inside bottom left of the windshield frame? Also the front turn signals are larger round than smaller ones on the earlier CJs. How's the frame, check for rust and possible patches.
RiverandSand is offline
post #3 of 16 Old 06-22-2021, 11:50 AM Thread Starter
CrustyCJ5
CrustyCJ5's Avatar
1972 CJ5
Thanks for the reply - Agreed I'm skeptical it's a factory engine, going to dig in this week to look for evidence of a swap. Yes the wiper motor is mounted to the windshield frame bottom left. Frame and body are in surprisingly great shape (besides the paint color ) which is one of the reasons I picked it up.
post #4 of 16 Old 06-22-2021, 12:01 PM
Fourtrail
1974 CJ6
That tub is a 72-75 CJ-5. Look at the location of the Jeep stamping in the tub. 72-75 was still high on the panel with lowercase e's. Does look like the windshield has been swapped for one from a later model.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #5 of 16 Old 06-22-2021, 02:14 PM Thread Starter
CrustyCJ5
CrustyCJ5's Avatar
1972 CJ5
Yea the windshield does look like it's been swapped from a later model, the original paint colors do not match up. The VIN matches a 1972 CJ5 304 w/ Toledo 3-spd/LHD.
post #6 of 16 Old 06-22-2021, 06:36 PM
RiverandSand
1980 CJ5
Ah thanks..I got hung up on the windshield frame and missed the jeep logo position. Those 72 to 75s are definitely unique.
post #7 of 16 Old 06-22-2021, 07:38 PM
Hurricane4
Hurricane4's Avatar
1979 CJ5
Those front leaf spring shackles look scary.
"The unbelievable we can do immediately . . . the impossible just takes a little longer."
My College Accounting Professor
"Success is not final. Failure is not fatal. It is the courage to continue that counts"
Winston Churchill
Jeeps I Have Owned in Year Order:
'61 CJ5, '63 CJ6, '78 CJ5, '79 CJ5 (Current), '79 CJ7 & '86 CJ7.
Hurricane4 is offline
post #8 of 16 Old 06-23-2021, 07:24 AM
bob4703
1974 CJ5
The 360 claim may be a selling point. Don't think you can tell the difference between a 304 and a 360 just by looking.
W/S wiper motor should be on the outside. Wipers are 180* out but if the PO used the original wiper motor on the inside they will run backwards. No sweat it they work. It should have low back seats too. Front of frame and shackle brackets need to be inspected closely.
Please fill out your profile so we can know more about you.
Good luck!
Paved roads are prime examples of government over spending!
bob4703 is offline
post #9 of 16 Old 06-23-2021, 08:50 AM
Fourtrail
1974 CJ6
you just finger the block behind the drivers side motor mount to find the displacement...
post #10 of 16 Old 06-23-2021, 09:01 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Yup, the displacement is cast into the block, but it's not easy to see when the engine is installed.
Matt
Matt1981CJ7 is offline
post #11 of 16 Old 06-23-2021, 02:30 PM
bob4703
1974 CJ5
If you looked at two Jeeps sitting side by side with the hoods raised one with a 304 and the other with a 360 could you tell the difference by looking?
bob4703 is offline
post #12 of 16 Old 06-23-2021, 02:33 PM
Fourtrail
1974 CJ6
Looking, no, touching yes.
post #13 of 16 Old 06-23-2021, 03:02 PM
Matt1981CJ7
1981 CJ7
Yes, if the original build tag was still on the passenger side valve covers, and you knew how to decode them.
But I get what you are saying. The 2 engines look identical.
Matt
bob4703 likes this.
post #14 of 16 Old 06-23-2021, 06:50 PM Thread Starter
CrustyCJ5
CrustyCJ5's Avatar
1972 CJ5
Yea from what I understand the blocks are the same, just different bores. Correct, the displacement is cast right under the driver side mount.
Thanks!
post #15 of 16 Old 06-24-2021, 06:01 AM
BagusJeep
BagusJeep's Avatar
1981 CJ7
The VIN numbers were not put on the blocks and the cast numbers were shared between years and displacements. The only other way of checking is to find the cylinder head cast numbers, which were year specific, and looking for dates on the manifold.
No 360 V8 was supposed to leave the factory in a CJ5 but that does not exclude a dealer fit or a little experimentation at the factory. Replacement / service blocks were often produced for replacements without any number cast in the side, but that may not be a rule.
However, if you find the heads are a different year, it would most defo not be a factory 360 and not a "holy grail" CJ.
BagusJeep lives in Bali with far too many 4x4s:
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
1980 Land Rover Series III 109" troop carrier - ROVER
BagusJeep is offline
