1959 cj5 - JeepForum.com
 1Likes
  • 1 Post By BagusJeep
post #1 of 9 Old 12-12-2019, 11:51 AM Thread Starter
littleblackjeep
1959 cj5
Got this thing a few months a ago.
Specifics:
Running F head
- doesnít run long. Once warmed up dies and wonít fire. Going to start with a new condenser and go from there.
- Brakes stop it, probably need adjustment and rebuild
- Trans and tcase feel good
- I pulled the nasty cable off the Koenig on the front and strung a good piece of rope (not permanent) oiled everything and low and behold, the full PTO system works and winch runs
- glass is ďgoodĒ
- Willyís body and Koenig hard top are straight and complete. Doors donít seal great/latch firm.
- electrical everything seems to work, but I havenít been into it enough to see what bubba has done
- really good shape bfgoodrich silverstar tube bias tires
- driver floor and tailgate are shot, but Iíll cut out whatís no good and replace with new panels
Questions:
Is there an overdrive PTO set up that works with a winch pto?
How much is a F-head rebuild good for, I live pretty close to a 55mph highway and this thing will need to climb a pretty decent hill w/o being a safety hazard
Would pulling the f-head and going with a rebuilt 231 odd or even fire rebuild be a better route? Iíd want to keep the T-90/d18/winch pto.
Not going to lift or wheel. Just thinking about having a fun run about thatíll play on mountain roads and motivate down the road pretty well.
As far as paint the Jeep was/is 60yr old Metallic Amber, my wife as a more colorful name for the current color. The windshield is the black that came typically, as I understand. The hard top is a cream inside and out. The body is straight enough to warrant a paint job. Options:
- Go original, tri-color?
- Go with a cleaner paint scheme I saw a Ď62 CJ5 on bring a trailer archives that was more aesthetically pleasing doors/windshield body color etc. thatís close to era specific colors
- Go with a more contemporary scheme, 1995 YJ Sahara moss green/tan top or 2016 JK hydro blue and cream top?
Any ideas, thanks.
'95 YJ
GM 350, SM420, NP231 SYE, Fnt. D60 SOA 4.10, Rr. D60 SOA 4.10 Detroit Locker, Fnt.Sus. N/A. Rr.Sus. XJ Springs, RuffStuff Wayback.
YJ Build: https://www.jeepforum.com/forum/f22/my-girlfriend-1327158/
littleblackjeep is offline
post #2 of 9 Old 12-12-2019, 12:12 PM
TerryHowe
TerryHowe's Avatar
1949 CJ3A
Yes, I've seen a PTO that bolts on the back of the Warn OD. I'm not sure if you need special parts for that or if the OD has a similar output as the D18
I would recommend the even fire version since it not only comes with the big cap HEI, but you can fuel inject it if you like. The are nice running engines and easy to maintain.
As far as paint the Jeep was/is 60yr old Metallic Amber, my wife as a more colorful name for the current color. The windshield is the black that came typically, as I understand. The hard top is a cream inside and out. The body is straight enough to warrant a paint job. Options...
I would go two color. I always thought the black w/s makes it look like you damaged the original and were too lazy to paint it. It is like having a gray Jeep and everyone things you haven't painted it yet.
The cream or tan I think would be nice for the top depending on the body color.
Terry Howe
'49 Willys CJ-3A
TerryHowe is offline
post #3 of 9 Old 12-12-2019, 12:43 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Yeah, I never liked the back w/s frame either. Paint the jeep all one color and the top a white color.
I had an f-head for a couple of years and 55 mph was a challenge.
Those vacuum wipers made a cool sound when running but you might want to get the electric conversion for those also.
Does your PRO have a front and back takeoff Like this:
I would also go with the even fire engine.
We need more pictures !!
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #4 of 9 Old 12-12-2019, 01:25 PM
Fourtrail
1974 CJ6
Which PTO do you have? The one that mounts off of the bottom or off of the back to the tcase? 5.38 gears or 4.88's in the axles? 5.38's are a bit much with a 30 or so inch tire to run 55 for long periods of time with either the f-head or the v-6. most of the v-6's got optioned with 4.88's. The other part of running 55 with a 59 is getting the steering and brakes in good enough shape to do so.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is online now
post #5 of 9 Old 12-12-2019, 06:15 PM
Hurricane4
Hurricane4's Avatar
1979 CJ5
When I owned my '63 CJ6 30 years ago with the original F-Head and full metal hard top
I had to press the accelerator pedal to go downhill. No kidding!
The CJ6 was a former Fire Dept vehicle and had maybe 2500 miles on it. I look back
and wish I never sold it. Different times.
"The unbelievable we can do immediately . . . the impossible just takes a little longer."
My College Accounting Professor
"Success is not final. Failure is not fatal. It is the courage to continue that counts"
Winston Churchill
Jeeps I Have Owned in Year Order:
'61 CJ5, '63 CJ6, '78 CJ5, '79 CJ5 (Current), '79 CJ7 & '86 CJ7.
Hurricane4 is online now
post #6 of 9 Old 12-12-2019, 11:27 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
What gear ratio's re you running now?
What's your budget?
Upgrades (IMHO) in order of importance:
Brakes. A dual master cylinder is a must. Either 11" Wagoneer brakes (getting hard to find, but a virtual bolt in) or front disks. I forget when the rears went to self energizing. Be sure you don't have the earlier style.
Saginaw steering upgrade. Either manual or power. You will never get the Ross steering to tighten up enough to be happy.
Inspect the frame around the spring hangers. ECJ frames are known to break in this area.
Wipers. If you want to keep the vacuum units, be sure the vacuum pump on the fuel pump is working or they will stop every time you step on the gas.
Dump the metal roof. Too heavy. It will make the Jeep sway on the mildest of corners. You will notice a huge difference with a soft top.
Bush/rebuild the pedals. They are probably loose and sloppy. Don't forget to inspect the clutch rod and bellcrank for wear.
Drivetrain: V6 (your option) SM series or a T18 and 3.73 gearing. The OD is nice, but they tend to be a bit weak and are getting expensive.
I recommend a 2.5 lift. It will ride better than the blown out stock springs and will give a bit more clearance between the frame and axles.
Ford early Bronco heater box. It will mount on the passenger side and will provide not only heat, but good defrosters as well.
The duty of a patriot is to protect his country from it's government
Thomas Payne
jeepdaddy2000 is offline
post #7 of 9 Old 12-12-2019, 11:37 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
The f head is more powerful than the L head but neither can be confused with the engine of a highway vehicle. the old thing will be a dream on back roads and trails. The imprecise steering, the noise, the sluggishness, leaning ito cures etc is all part of it.
You could rip it all apart and make it into a 1970s CJ5 with good steering and acceleration but is that the fate of a very original survivor?
Hurricane4 likes this.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #8 of 9 Old 12-13-2019, 04:44 PM
80cj
80cj's Avatar
1980 CJ5
Drivetrain: V6 (your option) SM series or a T18A and 3.73 gearing. The OD is nice, but they tend to be a bit weak and are getting expensive.
My brother did a Saginaw manual steering conversion on his 68 CJ-5 with V-6. Felt like power steering. He had a Koenig PTO winch on his and had to offset the winch and run new shafts for the PTO. Transmission was a T-18 A but still ran the PTO off the transfer case. He had 3.73 gears and it was a nice combination with the V-6 and T-18A (close ratio). As stated, the OD is a weak link. I had one on a CJ-6 that I did a 283 SBC conversion on. The OD made the 5.38 gears tolerable on the hiway but later found that the tips of the planetary gear teeth were bending over. Eventually pulled out the OD and went to 4.27 gears.
80cj is offline
post #9 of 9 Old 12-13-2019, 05:30 PM
TerryHowe
TerryHowe's Avatar
1949 CJ3A
I have a very low mileage manual Saginaw box I'm going to be selling if you decided to go that route. I pulled it off my '49 and the PO had installed it and I don't think he drove it much.
Terry Howe
'49 Willys CJ-3A
