1951 CJ3A Restomod - A Father/Son Project - Page 5 - JeepForum.com
 23Likes
post #61 of 71 Old 02-20-2020, 07:58 AM
JoonHoss
JoonHoss's Avatar
2011 JK Wrangler
That's AWESOME!
Congrats on the milestone!
Hoss
Good judgement comes from experience; experience comes from bad judgement
JoonHoss is offline
post #62 of 71 Old 02-20-2020, 11:00 AM
TerryHowe
TerryHowe's Avatar
1949 CJ3A
Looks and sounds great!
Terry Howe
'49 Willys CJ-3A
TerryHowe is offline
post #63 of 71 Old 02-21-2020, 06:12 AM Thread Starter
letitloose06
letitloose06's Avatar
Got a set of new gauges in the mail today and installed the coolant temp, oil pressure and the speedo into the temporary gauge panel. Oil pressure and coolant temp are right on the money after running for 15-20 minutes. My dad is going to bring his old school tach/dwell meter over on Saturday so we can fine tune the timing and get the carb dialed in. If all goes well, we may even take the chassis for a spin around the driveway
John Strenk likes this.
1992 YJ 4.0L, AX-15, 4" RE Standard Lift, 35x12.5R15 Maxxis Bighorn MT's, Grizzly Locked 8.8 Rear, HP44 with Spartan, 4.10's, Smittybilt Armor, JCR Off road Stage 2 Front Bumper, Custom Rear Bumper
1966 M416 1/4 Ton Cargo Trailer --
1951 CJ3A Restomod Project
letitloose06 is offline
post #64 of 71 Old 02-22-2020, 08:23 PM Thread Starter
letitloose06
Had some nice 45 degree weather here today, so we tried to get the carb and timing dialed in. It's looking like the carb has a leak somewhere . We weren't able to get it completely dialed in, but it was running good enough we decided to take it for a spin around the driveway!
Also found a couple of issues as well.
-The top of the shift tower is leaking a bit, nothing that a CV boot repair kit didn't fix
-Brake master cylinder cover leaks a bit.
Tracking down a better seal to see if that resolves it.
-Front seal on the engine is dripping, not sure if it's the seal or if the seal surface on the pulley is worn
-Also installed a 1/2" thick spacer on the passenger side rear spring to correct the "Willys Lean"
IMG_20200222_110635_exported_1699_1582391746199_1582428225454.jpg   IMG_20200222_134451_1582428462018.jpg   IMG_20200222_150853_01_1582428474040.jpg
post #65 of 71 Old 02-24-2020, 11:39 AM Thread Starter
letitloose06
A few more photos from the test drive this weekend.
NashvilleTJ and KevinCJ7Jeep like this.
post #66 of 71 Old 03-11-2020, 10:24 AM Thread Starter
letitloose06
The last 2 weeks have been a bit quiet, as we hit a funding roadblock and the next steps involve the body work.
However, this last weekend we sold the 1948 CJ2A that came with this Jeep (it was in much worse shape). So now we have cash for the project.
In the meantime, after several attempts as trying to solve the leaky carb, I finally gave up and sent it out to the Carter WO expert at "Old Jeep Carbs,.LLC" in North Carolina. Rick comes highly recommend from the flat fender community. He sent me some photos of his handywork prior to testing the carb and it looks great!
post #67 of 71 Old 03-27-2020, 07:52 PM Thread Starter
letitloose06
Well it's been a while since I've posted anything. Been working from home the last 2 weeks due to COVID19, so I've been able to get some work done. Unfortunately my dad has stayed away, he's 65 and we don't need him getting sick.
We got the grille back from the sand blaster and I repaired a few damaged areas. We also ordered a new fan shroud, as ours was missing. With the aluminum radiator, I had to come up with a different way to mount the shroud. Got it mocked up tonight. Time to blow it all back apart and get the parts ready for paint.
IMG_20200327_193406_1585360198796.jpg   IMG_20200327_193414_1585360234529.jpg   IMG_20200327_193439_1585360259806.jpg   IMG_20200327_194553_1585360283161.jpg
post #68 of 71 Old 03-31-2020, 12:15 PM Thread Starter
letitloose06
Got the grille in primer and the fan shroud painted over the weekend. Also started putting the headlight buckets back together. Waiting on a few parts to finish those out.
Bolted the grille and fan shroud back onto the chassis last night and installed the one complete headlight bucket. It's starting to look like a Jeep again!
IMG_20200328_145214_1585678570565.jpg   IMG_20200328_145244_1585678627689.jpg   IMG_20200330_174646_1585678648443.jpg
post #69 of 71 Old 03-31-2020, 08:50 PM
NashvilleTJ
I miss the snow...
NashvilleTJ's Avatar
I’ve always loved how gigantic those headlights look on those rigs. Lookin’ good.
Build Thread:
Swing Away / Swing Down Tire Carrier:
NashvilleTJ is offline
post #70 of 71 Old 04-02-2020, 07:53 AM Thread Starter
letitloose06
Took the chassis for a few laps around the driveway yesterday afternoon and stated working on the fenders. They are overall pretty solid rust wise, but they need some work fixing crack, dents, and extra holes that were added over the years. I mocked the fenders up quickly last night to check for clearance around the shock mounts and battery tray, as the fenders we have are from a CJ2A, and the inner fenders are slightly different.
Overall, the fitment is pretty good. Going to try to finish up the repairs tonight or tomorrow.
IMG_20200401_150616_1585835680142.jpg   IMG_20200401_205041_1585835719067.jpg   IMG_20200401_210402_1585835738819.jpg
caseypotts likes this.
post #71 of 71 Old 05-22-2020, 09:13 PM Thread Starter
letitloose06
Haven't had much to do due to lack of parts. However, that changed this week. Made a quick 2 day road trip to pickup the reproduction body tub we bought just before everything got shut down. Planning to start fitting the tub in the coming weeks!
