1951 CJ3A Restomod - A Father/Son Project - Page 4 - JeepForum.com
 25Likes
post #46 of 71 Old 01-16-2020, 06:03 AM Thread Starter
letitloose06
letitloose06's Avatar
Originally Posted by TerryHowe View Post
What is that master cylinder out of? Did it bolt up to the stock location?
I'm not sure what it's out of. We bought a dual resivour master cylinder kit from Herm the Overdrive Guy. It comes with a new bolt on bracket and you need to cut part of the frame where the original MC mounts for clearance.
Overall it's a pretty complete kit.
1992 YJ 4.0L, AX-15, 4" RE Standard Lift, 35x12.5R15 Maxxis Bighorn MT's, Grizzly Locked 8.8 Rear, HP44 with Spartan, 4.10's, Smittybilt Armor, JCR Off road Stage 2 Front Bumper, Custom Rear Bumper
1966 M416 1/4 Ton Cargo Trailer --
1951 CJ3A Restomod Project
letitloose06 is offline
post #47 of 71 Old 01-16-2020, 06:19 AM Thread Starter
letitloose06
Here a couple of photos of the MC mount. We opted to weld it instead if bolting it on to the frame.
TerryHowe likes this.
post #48 of 71 Old 01-17-2020, 12:42 PM Thread Starter
letitloose06
A family friend stopped by last night to check out the project last night. He snapped a photo of my father and I with the rolling chassis. If all goes well it will have the engine installed later tonight!
John Strenk, JoonHoss and Jim1611 like this.
post #49 of 71 Old 01-18-2020, 12:06 PM Thread Starter
letitloose06
Well after a few hours of wrench turning, the CJ3A has a drivetrain again! Probably the first it's had an engine in several years!
It's amazing how small these were compared to the more modern Jeeps!
MVIMG_20200117_210128_1579374188714.jpg   IMG_20200117_210118_exported_1380_1579374282365_1579374347829.jpg   IMG_20200117_210056_exported_1297_1579374301487_1579374359311.jpg   IMG_20200117_210045_exported_2242_1579374323867_1579374372014.jpg   IMG_20200118_101114_1579374380177.jpg
Jim1611 and NashvilleTJ like this.
post #50 of 71 Old 01-18-2020, 09:27 PM
NashvilleTJ
I miss the snow...
NashvilleTJ's Avatar
Love the YJ with the teeth in the background.
Build Thread:
Swing Away / Swing Down Tire Carrier:
NashvilleTJ is offline
post #51 of 71 Old 02-10-2020, 07:58 AM Thread Starter
letitloose06
Have been working on some small things over the last few weeks as funding for the project has been low. Getting my tax return this week, so some new parts will be on the way soon.
Started plumbing in the brake lines before my flaring tool broke [IMG class=inlineimg]/forum/images/JeepForum_2016/smilies/tango_face_sad.png[/IMG]. Ordered a new flaring tool and should have the brake system buttoned up sometime next week.
Overall the plumbing is pretty tight with the dual master cylinder and proportioning valve.
post #52 of 71 Old 02-11-2020, 07:21 AM Thread Starter
letitloose06
Started getting the grille cleaned up in preparation for mounting the radiator. Removed the radiator support pieces to repair some damage/rust as well as to clean the rust between the parts prior to priming it. While dong this, I think we have stumbled upon the 3A's original color. Under the grille welting, and behind the headlight buckets, the paint appears to either be "Hampshire Green Poly" or "Emerald Green". We haven't decided on a color yet, as we're a long way away from that. Although, considering how much of this Jeep is not original, it might be cool to at least have it's original paint color.
We also put the grille on the frame for a few quick photos.
IMG_20200210_183517_1581431174553.jpg   IMG_20200210_201904_exported_2719_1581431049402_1581431216417.jpg   IMG_20200210_201915_1581431230138.jpg
JoonHoss and TerryHowe like this.
post #53 of 71 Old 02-11-2020, 10:36 AM
JoonHoss
JoonHoss's Avatar
2011 JK Wrangler
At the local 4x4 shop I used to work at, when someone mentioned 'going back to the original color', we always jokingly said, 'was it red, or was it green?'
Seems that almost every older jeep that has been repainted was at one point one of those two colors...
Looking great so far; keep it up!
Hoss
Good judgement comes from experience; experience comes from bad judgement
JoonHoss is offline
post #54 of 71 Old 02-11-2020, 11:17 AM
mdawg4x4
mdawg4x4's Avatar
2017 JK Wrangler
Looks like your YJ shot down a 2 Xterras and 3 FJ Cruisers!
98 TJ Sport, 2017 JKU Rubicon, 2018 WK2 High Altitude HEMI
mdawg4x4 is offline
post #55 of 71 Old 02-11-2020, 11:38 AM Thread Starter
letitloose06
Hoss
This seems to be true from my experience as well. I've seen a lot of brown flat fenders as well.
This Jeep appears to have been at least 3 or 4 different colors over it's 60+ years of existence. After a quick google search I'm liking the look of Emerald Green on a flat fender.
We should be making some good progress over the next couple of weeks. USPS, FedEx and UPS are going to be making a lot of trips to my house in the coming days...
post #56 of 71 Old 02-12-2020, 08:27 PM Thread Starter
letitloose06
A bunch of parts came in today! The exhaust system, new accelerator pedal, brake fittings and flex lines and a new shinny steering wheel! Spent the evening installing the exhaust and finishing up the brake lines. Should be able to bleed the brakes this weekend. Once we get the radiator, we'll be really close to having a running chassis!
We also fabed up a temporary gauge panel for a speedo, oil pressure and coolant temp gauge.
IMG_20200212_202837_1581564356940.jpg   IMG_20200212_202850_1581564371974.jpg   IMG_20200212_202857_1581564387871.jpg   IMG_20200212_203016_1581564399002.jpg   IMG_20200212_202913_exported_2133_1581564053521_1581564410791.jpg
post #57 of 71 Old 02-14-2020, 06:33 PM Thread Starter
letitloose06
Brakes are bled and leak free! Also got this nice aluminum radiator today!
post #58 of 71 Old 02-15-2020, 08:53 AM
PLM
Awesome project. Looking great!
PLM is offline
post #59 of 71 Old 02-16-2020, 11:42 AM Thread Starter
letitloose06
We fabed up a temporary fuel tank courtesy old Tecumseh Snow blower engine and a temporary support for the radiator. Just waiting on an oil pressure and coolant temp gauges and we'll be ready to test run the engine soon!
IMG_20200216_123600_1581878467035.jpg   IMG_20200216_123610_exported_2424_1581878517205_1581878524422.jpg
post #60 of 71 Old 02-20-2020, 07:40 AM Thread Starter
letitloose06
The engine is a runner again! Still need to dial in the timing and carb adjustments, but it runs pretty good all things considered.
